Offline BenP
#1 Posted : 27 June 2024 21:27:07(UTC)
BenP
My ready-for-move layout was damaged by basement flood. Boxes full with vintage track, switches, signals and some locs were submerged. The cleaning and testing has started. Locs internal mechanics typically survived after lube, but some decoders did not.
Track suffered most as metal rusts. Using WD40 and brush to loosen and clean, which works well. More than 80% of switches work again (solenoids don't rust). This application leaves a fatty residue, so after laying track some light sanding to smooth and diluted paint thinner wipe to clean residue. Other treatment suggestions are welcome.
Pic shows unaffected and flooded M track. Excessive rust look is dusting from dried iron-rich well water.
thanks 3 users liked this useful post by BenP
#2 Posted : 27 June 2024 21:40:50(UTC)
Hi Ben
I am really sorry for you.
When reacting rapidely, your WD40 treatment plus wiping the oild residue is very fine.
Paint thinner is dangerous because any contact with paint will damage it. Some use lighter fluid instead. Others use NOCH SR24 (a cleaner that is also a smoke liquid.
Sanding: as you know the issue on rail surface is to create thin grooves in which, later, the oily residue and traction tire residue will accumulate and create contact problems.
So my advice is to use "water abrasive" with a grain of 2000 or higher (5000), of course without water. Water is only used with them to polish paint on car bodies
Don't forget to clean with WD40 the INSIDE of coils (the brass guide and the iron core) and all the thin steel wires on signals etc (cotton swab?)
Coils don't rust? Yes but humidity may stay between the winded enameled wire and cause corrostion or other unpleasnt aging. Maybe a small treatment with an hair dryer will help you.
I am not a specialist as you know but on my first layout in my father's cellar we had water damage (40 cm of water) so I know a bit about consequences. Better a very very thin residue of WD40 which will stop corrosion (especially under the track)
#3 Posted : 28 June 2024 14:22:09(UTC)
Excellent weathering! ThumpUp
Offline rhfil
#4 Posted : 28 June 2024 14:45:43(UTC)
rhfil
Smoke fluid is essentially expensive kerosene. And sanding the surface of the track is definitely to be avoided. I would try Orange Cleaner as a non-petroleum based cleaner and if it does not work move up to the least strong solvent. I use alcohol on felt furniture pads to clean the surface of my c-track. It evaporates and leaves no deposit on the rails.
thanks 3 users liked this useful post by rhfil
#5 Posted : 28 June 2024 17:47:39(UTC)
There used to be a product calle naval jelly that removes rust without harming paint.
This page was generated in 0.239 seconds.
