Offline fabstar68
#1 Posted : 21 June 2024 14:41:53(UTC)
fabstar68
hi all,
i'm a novice to Rocrail and i am trying to figure out by myself most of the stuff, but i'm having trouble understanding the following aspect : i have one block on the "left" ("L"), and two blocks on the "right" ("R1" and "R2). R1 and R2 have one route each coming from L1. However, for both R1 and R2, there are two different phisical routes that can a train can follow from L to Rx, due to the presence of several turnouts in between. so, do i have to create, for both R1 and R2, two routes each, which are identical in terms of starting and ending block, but they differ on the commands to give to the turnouts ? and what happens when you (manually or automatically) set a course for a loco/train from L to R1 or R2 ? does Rocrail choose at random ?
Also, i read in the documentation that a route muse connect only adjacent blocks. but, in the route details, i see the option "via blocks..." where you can specify a list of blocks..... so is the documentation not updated, or is this an advanced option, or did i get it wrong ?
thanks,
Fab
Offline PMPeter
#2 Posted : 21 June 2024 15:36:39(UTC)
PMPeter
If you use Rocrail's Route generator it will automatically set all of the possible routes via the various switches between the blocks. It will then randomly select the route it uses when in Automatic mode.
The Via blocks is for a totally different purpose. It identifies Crossing Blocks for long trains. For example if you have a 3 block scenario Bk1, Bk2, and Bk3, and a train length that fits in BK1 and BK3 but not BK2, you would need to identify BK2 as a Crossing Block for that train to be able to use the route BK1-BK3.
Offline fabstar68
#3 Posted : 21 June 2024 16:05:22(UTC)
fabstar68
Immagine.jpgthank you very much buddy, that was really helpful and clearly written. i hope to be able to help you back one day. BTW, i am having a hard time understanding how to configure Marklin 24624 double slip switch with Rocrail... i have read the documentation, and it clearly says to define them as crossings, but in this way they are not recognized in the router as switches, so i have to manually insert the routes that that router doesn't discover, right ? i attach the screenshow of an automatic created route, where you can see that T-1-2 (the crossing switch) does not have a command, and as i said it is not detected for alternate paths that are, instead, available.
thanks 1 user liked this useful post by fabstar68
#4 Posted : 21 June 2024 23:58:40(UTC)
Hi Fab
Yes all my 24624 are defined as crossings
Here is one of them and its properties
Here is the digital interface tab (ONE motor is declared)
Note: a regular crossing is called by Rocrail "Center Crossing". Even it has no motor, it is part of an itinerary to prevent collisions (2 trains trying to use the same crossing, on reserves the crossing to avoid collision.
Doing this allows the router to create ALL the routes.
In fact, on complex track piece arrangement, some routes are stupid and need be removed.
This page was generated in 0.576 seconds.
