Offline Drese Alain
#1 Posted : 05 June 2024 09:18:07(UTC)
Drese Alain
Hi is used below commands to access icons
On latest update this no longer works (?)
http://192.168.123.44/fcticons/FktIcon_a_we_X.png
Replace X by the icon number you need
Numbers go from 0 to 112
For numbers from 150 on, you should deduct 128 to get the correct icon.
A stands for active, I for inactive
We stands for white, GE for yellow
#2 Posted : 05 June 2024 13:50:02(UTC)
That link looks suspicious, as it will be a link on your own internal network, not out on the internet. The rest of the link looks like it doesn't have the full path required to get to the required directory.
#3 Posted : 05 June 2024 15:36:31(UTC)
Hi Alain
Not sure here but this is what I think (and used in the past):
- Indeed the IP address is the one of your own CS3
- why not use one of the multiple links offered between the CS3 and your computer (direct IP connection using your browser, RealVNC Viewer, smartphone connection through WiFi, etc)?
Whith the 2 last Updates 2.5.1 and 2.5.2, Märklin has completely reworked the web link provided by the CS3
One possibility to access all loco icons is:
- to connect the CS3 to your PC (direct cable CAT5 link or through a WiFi router and your regular web browser like Edge in my case)
- to start creating a new loco and click on the icon.
- then you have access to Märklin Icons (CS3/Lokicons or your own icons on one of the external memories (up to 3)
- then select the icon you want and you may upload it. It will land on your PC's download folder.
Agreed you can't upload all icons in one go but you have access to all of them
Offline Drese Alain
#4 Posted : 05 June 2024 17:37:36(UTC)
Drese Alain
Hi Jean,
I am using my own software from a windows PC and it used to work with the example above.
I can still access the lok icons however not the functions for the loks
R
Alain
Offline moman2
#5 Posted : 28 December 2024 09:14:18(UTC)
moman2
In the new update, the icons are available as SVG files only, and it is no longer possible to use the old method of fetching them. Here's a sample URL:
http://{your cs3 ip}/app/assets/fct/fkticon_i_001.svg
The index goes all the way up to 296, with a gap between 176 and 197. I made a script that uses imagemagick to save them as a PNG in any color you want:
https://github.com/bob12...er/assets/scripts/svg.py
Or you can just download the icons directly:
https://github.com/bob12.../gui/resources/functions
This page was generated in 0.288 seconds.
