Offline Ivan
#1 Posted : 24 May 2024 08:51:40(UTC)
Ivan
Old Faller relais 649 can be used as a simple switch, e.g. to turn on the lights when the train passes desired location on the layout.
I am helpless how to connect it. Light bulbs can be connected in two pairs (green pair and red pair - plugs 1, 2,3 and 4). There is a pin inside, which moves through the solenoid when activated and closes the circuit, either I or II. But that`s all I can figure out.
Where is transformer connected and how ? How to connect Kontaktgleis ? The solution should be in three plugs on the opposite side (blue - yellow- blue).
There is a schematic drawing in 649 manual, but it is not well explained, still - might help someone who is more familiar with it.
Thanks for your kind attention and answers.
Offline RudiC
#2 Posted : 24 May 2024 09:36:37(UTC)
RudiC
The switch should be connected like any other solenoid (e.g. turnout motors): yellow to the yellow "light" transformer output, blue X and Y, respectively, to a push button or a contact track. Red and green are opened or closed alternately by the slider inside the solenoid.
Rüdiger (Rudi)
Offline Ivan
#3 Posted : 24 May 2024 10:03:49(UTC)
Ivan
If so, transformer must have two connections L and 0 (Masse). Where is Masse connected ?
Offline French_Fabrice
#4 Posted : 24 May 2024 17:03:53(UTC)
French_Fabrice
Hello Ivan
The following diagram is an example of how to switch on 2 lamps alternately;
When the green button on the 7072 is pressed, Lamp 2 is switched on and Lamp1 is off;
When the red button is pressed, Lamp 1 is switched on and Lamp2 is off.
Fabrice
Offline Ivan
#5 Posted : 24 May 2024 17:35:41(UTC)
Ivan
Hello Ivan
Fabrice
Thanks Fabrice,
I tried in several Maerklin groups. You are the first one with clear explanation. No wonder France is the only nuclear power in Europe. We all rely on you and your technology and determination. Best regards.
Offline ccranium
#6 Posted : 25 May 2024 00:25:57(UTC)
ccranium
"No wonder France is the only nuclear power in Europe. We all rely on you and your technology and determination."
That is an awesome reply! Thank you!
This page was generated in 0.279 seconds.
