Offline mvd71
#1 Posted : 20 April 2024 12:36:09(UTC)
Hi guys,
I am trying to look at options for NEM pockets to fit a Hag Re 6/6 and Re 4/4. The idea is to run them together as an Re 10/10. When I looked at the pockets available as spare parts, they all have different lengths, however I have to referents as to where the measure from. I need to confirm if the dimension they list is the overall length, or the length from the centre of the mounting screw hole, to the end of the coupler pocket.
If anyone could clarify this, it would be much appreciated.
Cheers…..
#2 Posted : 20 April 2024 15:15:54(UTC)
Hi Mike
Here is the content of NEM pocket standard, giving you all the needed information
https://doubleogauge.com/nem-coupling-pockets/
Same standard for any serious train manufacturer
Normally it shouldn't pose you any problem to use any coupler you like (Märklin KK, Roco, etc)
Offline Unholz
#3 Posted : 20 April 2024 18:21:23(UTC)
Unholz
Here is a table showing the various HAG coupling hooks and adaptors that used to be available in the good old days before the current kitbashers took over.
#4 Posted : 20 April 2024 20:12:04(UTC)
I have the Re 10/10 Set (Ziegelbrücke) in the SBB Cargo livery. I can send you photos of how the two locomotives are attached if you would like.
I installed a slider on both locomotives so that they can also be used individually. For a while, the Hag Re 420 Cargo was the only one that I had in my collection, the others all being Re 421. I now have a similar model from Roco as well.
Offline mvd71
#5 Posted : 21 April 2024 00:18:09(UTC)
Thanks Jean, not quite what I was after but interesting to have that info.
Cheers….
Offline mvd71
#6 Posted : 21 April 2024 00:19:16(UTC)
Hi Stefan,
Thank you, that is perfect. Now I can order parts with some confidence!
Cheers….
Offline mvd71
#7 Posted : 21 April 2024 00:20:25(UTC)
Hi Mike,
Thanks, some photos would be great 👍
Cheers….
This page was generated in 0.485 seconds.
