Offline mattj70
#1 Posted : 25 February 2024 12:58:53(UTC)
mattj70
I have been using my CS2 just fine however the Stop is on when I turn it on, not even contected to the track? I turned on and on, Stop light flickers when turning on then is stuck on Stop? Any ideas on how to fix?
Matt
thanks 1 user liked this useful post by mattj70
#2 Posted : 25 February 2024 17:32:51(UTC)
Hi Matt
Not sure what you talk about (so my answer may be off subject)
- the initial s/w versions of the CS2 allowed it to start with power on but this can cause accidents
- the software versions since quite a white start with a STOP button active. This happens also when the CS2 is not connected to anything and is a precaution measure.
A loco with former high-speed instruction (before power off) could zoom your layout and destroy something.
Here is a real-time video of my CS2 cold start (to compare with yours)
STOP Light flickers: does this mean that when pushing the STOP bar it does not turn off? (and sends power to the layout)
In some cases a CS2 when falling down may have its stop bar out of position. Is it raised so that there is some clearance to push-down (2 mm or so.
#3 Posted : 25 February 2024 17:38:08(UTC)
The digital webinar covered the CS2 last week. Many are experiencing slow reactions, and unwanted restarts, etc. the memory in them is very near full capacity because of all the updates and depending on how much data you have on it.
#4 Posted : 25 February 2024 19:15:21(UTC)
No good talking about a webinar if you don't link to it.
#5 Posted : 25 February 2024 21:52:32(UTC)
Not difficult to find on YouTube. Marklin digital webinars 2024. The link was sent from Marklin with the digital club newsletter.
This page was generated in 0.402 seconds.
