Offline einotuominen
#1 Posted : 17 February 2024 11:44:17(UTC)
einotuominen
In order to fit smoke unit to some retrofit diesel locos, the standard tube shape will not fit, so I thought I’d make one myself.
Here’s the schemantics:
So it’s a coiled wire that is connected to the decoder. The coil is wrapped with a cotton swap that is soaked with smoke fluid. The whole thing is assmbled to a shallow pool that will fit to the US brand diesel locos.
What material should the coil be and can I connect it between U+ and Aux1? What about Aux1 and ground instead?
What about the cotton swap? Is it a bad idea or should the smoke fluid just be freely in the pool/container with the coil in it?
Thanks!
-Eino
Offline cintrans
#2 Posted : 17 February 2024 14:43:13(UTC)
cintrans
Aruba
Not a good idea Eino!
The styrene and cotton will catch fire due to the heat of the coil....
Did you ever feel how hot a smoke generator gets in a steam lok?
Jean-Pierre
#3 Posted : 17 February 2024 14:46:49(UTC)
Jean-Pierre
Isn't this the whole idea to get real smoke out of the generatorBigGrin
#4 Posted : 17 February 2024 15:10:07(UTC)
einotuominen
Yeah Laugh
But there’s a lot of videos online where people make these in plastic bottle caps…
-Eino
Offline dickinsonj
#5 Posted : 18 February 2024 01:02:26(UTC)
There are a lot of videos online of people doing many things that I would not recommend, and this is one. BigGrin
#6 Posted : 18 February 2024 08:13:28(UTC)
einotuominen
So let’s forget about all the plastics and replace them with metal parts.
What would the plan looklike then?
-Eino
Offline Tie
#7 Posted : 19 February 2024 10:05:57(UTC)
Tie
Interesting idea… must admit it has occurred in my mind to…
Still I think it might be too challenging.
I think I remember having measured the resistance of a smoke generator to approx 45 Ohm. At 12 volt dc this would require 0,26 Amps. Then I do not know if resistance in coil measured when cold will change when heated. Normally I think these coils are made from nickelchrome wire as used in styrofoam cutters. But I have not found info of resistance pr m wire. 0.1 mm wire is possible to procure…
Also other materials may be used that I do not know of.
Still. Keep us in the loop if you go further with your idea.
Thor
thanks 1 user liked this useful post by Tie
#8 Posted : 19 February 2024 10:29:29(UTC)
einotuominen
Maybe the biggest question here is what should I do / not do in order to keep the decoder alive and not burn it in process.
-Eino
Offline mbarreto
#9 Posted : 19 February 2024 12:47:45(UTC)
mbarreto
Isn't it easier to use a normal Seuthe smoke generator and just do a metal adapter to the locomotive?
You can use screws or glue to fit the adapter to the locomotive body. the screws will look worse, but I don't know if there is any glue that can support the high temperatures.
Maybe others have a better idea to attach the adapter to the locomotive body.
Miguel
Mostly Märklin H0.
#10 Posted : 19 February 2024 12:52:13(UTC)
einotuominen
This would be the case with older Märklin locos that are mostly empty inside, but the locos I have, got centrally mounted motors with dual flywheels and a big frame for weight. So there is maybe 8mm space between the hull and the plastic body of the loco.
-Eino
thanks 1 user liked this useful post by einotuominen
Offline mbarreto
#11 Posted : 19 February 2024 18:16:49(UTC)
mbarreto
Ok, I understand there is not much space inside.
You can take a look (in case you didn't already) at the Seuthe several products (link to the page below) to check if some fit, although probably not if the space is really small:
Seuthe H0 smoke units
Miguel
Mostly Märklin H0.
Offline Tie
#12 Posted : 19 February 2024 18:23:01(UTC)
Tie
Whatever You do… I assume some testing prior to installation in loco would be required.
Thor
#13 Posted : 19 February 2024 19:27:38(UTC)
einotuominen
Thor
Absolutely!
Offline Tie
#14 Posted : 20 February 2024 11:45:44(UTC)
Tie
New idea: if the goal is smoke, not a homemade smoke generator… you cold drill a hole in the metal frame and mount a smoke generator vertially. (Type with cables to decoder. Then extend outlet with a silicontube to top of loco.
Thor
#15 Posted : 20 February 2024 12:00:58(UTC)
einotuominen
Thor
This will work on some cases yes. It depend on the loco and the location of the smoke exhaust. On some points there maybe a flywheel too close etc.
But will work on some locos yes.
-Eino
Offline Tie
#16 Posted : 20 February 2024 13:01:21(UTC)
Tie
I just compared with my br218. Think it would work. Cold also 3d print the outlet to get twin exhaust.
Thor
