Offline mrfixit
#1 Posted : 14 December 2020 14:49:34(UTC)
mrfixit
I need some assistance, please. From a 5'X9' layout which my dad bought for me in 1960-1961, I have an assortment of 3 rail track, switches, 2
transformers, and 2 powered engines. All of the wiring is pretty well gone--cracked and brittle, and some of the track is pretty rusted.
Since I want to keep and resurrect this set, I can use suggestions on how to repower and clean the track, and get is operational again.
My wife wanted to buy me a Marklin piece for Christmas, but until I know how to get the current project up and going,
I deferred.
Mr.fixit
thanks 1 user liked this useful post by mrfixit
#2 Posted : 14 December 2020 18:44:04(UTC)
replace the power cables on the transformers.
Take an old PC power cable, unplug it and then cut the PC end off.
Unplug transformer.
Open up the metal transformer case by bending the metal tabs on the bottom.
Take picture of connections.
Remove old power cable.
Thread cut end of PC cable in, tie a knot so it can't be pulled out.
Strip the wires and connect to the original connections.
Reassemble.
Test
#3 Posted : 14 December 2020 19:24:56(UTC)
Thread cut end of PC cable in, tie a knot so it can be pulled out.
CAN´T! ;-)
-Or better yet; Let the X-mas Märklin piece be a 6646 white trafo!
#4 Posted : 14 December 2020 20:16:03(UTC)
thanks Henrik, I fixed that bad typo!
#5 Posted : 14 December 2020 21:11:55(UTC)
Use C track or get a Marklin start set from Santa.
Offline Tom Jessop
#6 Posted : 14 December 2020 22:22:32(UTC)
Tom Jessop
Make sure that it is a 110 volt transformer & not a 220 / 240 volt transformer otherwise you will have some interesting fireworks .
Cheers & a Merry Xmas
Tom in Oz .
thanks 2 users liked this useful post by Tom Jessop
Offline mrfixit
#7 Posted : 14 December 2020 22:34:09(UTC)
mrfixit
Thanks for that information. It will help me repower my 2 transformers. What size wire do I use to replace the power and ground wires on the middle and outside rail. and what kind of terminals do I use to connect the wires to the transformers?
I have figured out how to remove the rust from the rails.
Offline mrfixit
#8 Posted : 14 December 2020 22:45:56(UTC)
mrfixit
Unplug transformer.
Reassemble.
Test
Tom in Oz .
Hi Tom,
Yes, it is a 110 Volt transformer. Will you please look at my question regarding size of wire for power to middle rail and outside rail, and the type of electrical pin connector to connect said wires to the transformer? My transformers have 3 sets of connectors. 1 for rail power, 1 for overhead wire power, and 1 for switches. I really don't want to change to the C rail as the 2 powered cars run on the center rail .
My dad always wanted me to go down under, as he was stationed in Perth after the war. Any help is greatly appreciated.
Merry Christmas
Paul in retirement.
#9 Posted : 15 December 2020 09:05:34(UTC)
Make sure that it is a 110 volt transformer & not a 220 / 240 volt transformer otherwise you will have some interesting fireworks.
Note that transformers made for 110, 220, or 240 volts must not be used with modern digital locos.
Better get a current transformer for the local voltage - 120 or 230 volts.
Offline mrfixit
#10 Posted : 15 December 2020 14:10:35(UTC)
mrfixit
Good morning Tom,
Thanks for the input. Both transformers are for 110 volt, and both engines are from the same timeline. I researched the track, and it appears that I have #3800 and #3900 track. Some of it it is running shape and some of it is quite rusty, and is be resuscitated now.
Is a current transformer compatible with my older track and engines?
Paul
#11 Posted : 15 December 2020 14:43:18(UTC)
Yes!
Offline Don Mebius
#12 Posted : 17 January 2024 03:18:53(UTC)
Don Mebius
I would add a simple method of removing rust from the M tracks.
I use an old toothbrush and dip it in rubbing alcohol (isopropyl) and scrub.
It doesn't take long, and it cleans very well!
Good luck!
thanks 1 user liked this useful post by Don Mebius
This page was generated in 0.415 seconds.
