Offline Silentmoose
#1 Posted : 07 December 2023 19:22:30(UTC)
Silentmoose
Hello
It's my first time posting so hello everyone.
I ran into a problem with the "farm" start set 29344.
First I have to say it's the third train we buy and the 1st and 2nd train they don't have this problem.
The thing is with the locomotive of the farm set it keep getting stuck in the turns or derails when the rail sequence make an S shape ,it make the train completely useless. Is there something I can do to make it run good or there is something wrong with locomotive .
thanks 2 users liked this useful post by Silentmoose
#2 Posted : 08 December 2023 13:16:27(UTC)
Be sure the S curves are flat, and the tracks are clicked tightly. On occasion, even my heavy locomotives stop or don't want to go without a nudge forward or side to side. After running a little, they are fine. I noticed this mostly with my new MS2, and CS3 controller and not my older 6021 digital controller. That uses a conventional transformer and the new ones use switched mode power supplies. I don't know why this is. Certain decoders of the older mm fx type start running cold on the 6021, and need a warm up with the newer system. Mfx decoders seem to be the exception in my experience.
Offline Silentmoose
#3 Posted : 08 December 2023 13:50:30(UTC)
Silentmoose
Thanks for the reply, in the end I found the problem and I solved it with some oil.
thanks 1 user liked this useful post by Silentmoose
#4 Posted : 08 December 2023 14:24:29(UTC)
You didn't check what set it is - it happens to be one of the battery sets, so most of the above info is irrelevant.
However seems it is now running.
#5 Posted : 08 December 2023 14:43:38(UTC)
I figured it was a battery set. Even lower amperage.
Guest (4)
This page was generated in 0.245 seconds.
