#1 Posted : 03 November 2023 07:16:31(UTC)
Hi, I received the loco yesterday from Germany, unpacked it, changed a few light functions, including the cab lights, the loco is all metal, except a few plastic parts, the weight is 570 grams, 24.7cm long, has an inbuild smoke generator, when braking sparks come from the brake shoes.
I'm not completely chuffed about this loco, found out it only has 4 powered axles instead of six, not that it would make any difference regarding pulling power., I've chosen the "ONE" designed loco as I have already carriages with "ONE" containers, tried to get more but they've sold out, this was a bit of a dissapointement as the loco is a new construction and release and the container cars came out last year., looks like I have to resource them from somewhere else.
The loco drives fine, goes over all my K-track turnouts without any hassle, it also has 2 capacitors, so there is no stopping happening.
the inside of the loco is compact and nicely finished, no wires or other bits and pieces which would hinder the housing to be removed., it has 4 screws, undo them and the housing comes off with ease, inside you have 2 loudpeakers, smoke unit, 2 capacitors, top light is connected via spring pins on both sides.
The wheel arrangement is as follow: 1 axle with cogwheel without rubber tyre, 1 axle without cogwheel and is spring loaded (not a driving axle), 1 axle with rubber tyres and cogwheel., all three axles have track contacts., forgot to order the smoke fluid at the same time but I'm sure I can buy it within Australia,
thanks 7 users liked this useful post by river6109
#2 Posted : 03 November 2023 09:42:14(UTC)
A friend has this loco, it's a nice runner with good sound and sparking brakes. Not sure if I like the pink colour but will admit it is something different.
I've chosen the "ONE" designed loco as I have already carriages with "ONE" containers, tried to get more but they've sold out, this was a bit of a disappointment....
Easily fixed!
Containers
#3 Posted : 03 November 2023 11:46:23(UTC)
I like the ONE container scheme too. I have a Roco car with the same container.This loco is metal body yes John? ESU is top notch and they've even got a switch for the smoke ac or dc.
Some say that ESU smoke fluid is better. I've been using karosene in my Marklin models and it makes good smoke. Track cleaner too.
#4 Posted : 03 November 2023 11:50:55(UTC)
Easily fixed!
Containers
yes containers on their own are plentyful but not with wagons, the only reason I've selected this one because I have carriages (6) with "ONE" containers
#5 Posted : 03 November 2023 14:06:34(UTC)
Another extra: it has sprung buffers
This page was generated in 0.329 seconds.
