Offline 3864jk
#1 Posted : 23 October 2023 18:24:51(UTC)
3864jk
I would be grateful either for any instructions on the 5113 lamp or advice on how to remove the lamp cover to test/change the bulb.
Many thanks.
thanks 1 user liked this useful post by 3864jk
Offline twmarklinfan
#2 Posted : 24 October 2023 00:07:17(UTC)
twmarklinfan
Hi John
It’s a simple clip fit. I’ll send some photo’s tomorrow
Kind regards
thanks 1 user liked this useful post by twmarklinfan
#3 Posted : 24 October 2023 20:09:59(UTC)
twmarklinfan
Hi John,
I can’t work out how to send you a photo by replying to your post.
Anyway I hope you can see from the attached that two sides of the lamp cover have small clips which hold it in place on the mast. I have found the best way is to apply a little pressure to the base of the cover and gradually work it off. Be brave they are quite robust. The same mast is currently available as it fits the C track uncoupler!
Kind regards
Offline Crazy Harry
#4 Posted : 25 October 2023 15:57:23(UTC)
Crazy Harry
Many thanks.
Here's a photo of the disassembled lamp:
Just a slight tug on the upper housing will separate it from the post. Hope this helps. Cheers,
Harold.
Offline 3864jk
#5 Posted : 25 October 2023 18:34:19(UTC)
3864jk
Many thanks for the swift response and the lanterns came off easily for bulb testing.
thanks 2 users liked this useful post by 3864jk
This page was generated in 0.550 seconds.
