Offline Sashmeister
#1 Posted : 13 October 2023 08:44:34(UTC)
Sashmeister
Bulgaria
Hi guys,
I have an issue. I ve been trying to use the mDecoder Tool3 to reprogram a couple of Marklin decoders that come factory installed on their new models. Unfortunately as we know, these are locked and the program returns an error massage "this is not a retrofit decoder". Is there a way to bypass this? If not, how can i reprogram the function keys on the decoders (make F1 -> F2 for example)? I know i can use he Central Stations, but i dont own one. I run my trains with the Roco Z21 Multimaus system. Any ideas?
Sorry if this have been brought up before.
thanks 1 user liked this useful post by Sashmeister
#2 Posted : 13 October 2023 13:41:29(UTC)
I don't know if you can even do that with a CS 2 or 3. Only function icons, and second duration or momentary function is adjustable.
#3 Posted : 13 October 2023 14:09:11(UTC)
Can be done with Central Station 1, 2, or 3, or even ESU ECoS.
For decoders supporting DCC this can be done with any DCC controller. But without GUI support this is a real hassle.
Some factory-installed decoders do not support DCC.
Offline Sashmeister
#4 Posted : 13 October 2023 15:48:17(UTC)
Sashmeister
Bulgaria
These decoders support DCC as i am able to change the volumes, or other CVs using my Multimaus DCC controller. Any idea what CV i need to change to make my F14 -> F7 function for example? Or can i somehow "unlock" my decoder using the mDecoder tool and the decoder programmer 60971 so i could reprogram it to my liking?
#5 Posted : 13 October 2023 16:22:13(UTC)
Bad news: there is a table with about 40 rows and each row can handle each function key.
There are a few CVs for each rows.
There is a PDF on the Märklin site with more information.
A Central Station is the far easier way.
Offline patnaik
#6 Posted : 14 October 2023 02:30:51(UTC)
patnaik
I have used JMRI to change function mapping on a mSD/3. Complicated, but doable.
thanks 1 user liked this useful post by patnaik
Offline Diesel2000
#7 Posted : 31 October 2023 02:55:49(UTC)
Diesel2000
Factory decoders can’t be unlocked and trying to function map in DCC using the CV strings is very complicated. It IS possible to function map change factory decoders. The easiest way is to do it in the CS3: Loco Edit - Configuration - Mapping. The config GUI makes it easy to then change what outputs or sounds are triggered by which function key.
Edited by user 31 October 2023 15:40:47(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by Diesel2000
Offline bph
#8 Posted : 31 October 2023 11:25:49(UTC)
Hi guys, I have an issue. I ve been trying to use the mDecoder Tool3 to reprogram a couple of Marklin decoders that come factory installed on their new models. Unfortunately as we know, these are locked and the program returns an error massage "this is not a retrofit decoder". Is there a way to bypass this?
Originally Posted by: Diesel2000 Go to Quoted Post
Factory decoders can’t be unlocked and trying to function map in DCC using the CV strings is very complicated. It IS possible to function map change factory decoders. The easiest way is to do it in the CS3 - Configuration - Mapping. The config GUI makes it easy to then change what outputs or sounds are triggered by which function key.
You can reprogram newer factory decoders if the firmware is above 3.2.x.x, and Marklin has released the decoder project for that specific model. You will then need a CS3/(2?) connected to a PC, and you have to send the complete project from the PC through the CS3, to the locomotive on the programming track. This takes approx 45-50 minutes. Using a 60971 will not work. As long as you start with the specific decoder project you can change what you like, eg delete and sounds etc and change sound settings that you can not change using a cs3 alone. Usually, this works on mfx+ locomotives except for some very early ones with older decoders/firmware. On locomotives with firmware below 3.2.x.x but above 3.0.x.x, you can upgrade the firmware and make it work. but not on all. E.g it is not possible on the 39030 with firmware 3.0.0.17, because according to Mârklin the decoder is too old. Some early decoders have only a 32 MBit sound chip and you must make sure you don't exceed that limit, otherwise, the sound will be totally gibberish.
I have changed added and deleted sound files on several factory-fitted decoders without a problem. including changes to sound settings that can only be done this way. But even after a decoder is programmed in this way, it still shows up as locked if you try to use the 60971. so it's a way around the looking. not a removal of the lock.
Marklin Goppingen confirmed to me on the phone that this method of reprogramming factory-fitted decoders was not intentional, but also that they have no plan of fixing this "error". And in some cases, they provide a description to the consumer on how to do this.
Edited by user 31 October 2023 15:00:47(UTC)  | Reason: Not specified
#9 Posted : 31 October 2023 13:20:15(UTC)
Hi guys,
I have questionned Märklin Göppingen on this and I was confirmed that the factory-installed decoders cannot have their sound changed. They are locked and there in NO WAY to unlock them.
All the rest can be reprogrammed (mapping of fonctions, durations, motor characteristics, etc).
I suppose Märklin decision is not very wise but is guided to avoid programming failures and warranty additional costs to them.
Remember that unwise programming may lock definitly the decoder (it becomes unusable).
Example: I have a splendid 39241 SNCF 241 A 65 with miserable sound files, especially the whistle that sounds very "unfrench". If I want to change it, I need to buy an mSD3 decoder and then, I can program what I want
#10 Posted : 31 October 2023 14:53:27(UTC)
I'm not surprised they'd tell you that Jean. They want to sell decoders to those who want more or different functions and sounds.
#11 Posted : 31 October 2023 16:21:37(UTC)
Yes but this is stupid because I am not buying anymore mSD3 because they are outrageously expensive and I am pissed off.
How long will it take Märklin to understand that many of their competitors are allowing changes in programming.
Why not have a warning saying that if the decoder is reprogrammed the warranty does not apply to it any more?
Sooo many narrow-minded people in the world!
Edited by user 31 October 2023 22:36:17(UTC)  | Reason: Not specified
#12 Posted : 31 October 2023 20:55:55(UTC)
If the decoder is shipped without sounds programmed, and requires a decoder tool to do it, that should not void the warranty! Nor should be if a dealer installed the sound files and you wish to change it later. It is what they are designed to do.
Offline rhfil
#13 Posted : 31 October 2023 21:55:55(UTC)
rhfil
I agree with JohnJean and have the same 39241 with its set of passenger cars. The normal route of the consist was Paris to Basel or French cities. But the announcements are in German. Would much prefer them to be in French. Someone needs to figure out how to unlock the Marklin decoders.
This page was generated in 0.493 seconds.
