Offline rytter
#1 Posted : 30 September 2023 23:50:31(UTC)
rytter
Hi, I am in the process of drawing my layout and adding articles in my CS3. So related to that, is it somehow possible to do an area selection and move the selected items around, it cant be that you have to move each item individually???
Edited by user 01 October 2023 10:04:01(UTC)  | Reason: Not specified
#2 Posted : 01 October 2023 10:37:40(UTC)
At the top left , of the TrackEditor tool modal, refer to the 'selection' dropdown
1) Choose the 3rd/bottom option.
This will now allow you to do a 'click/tap and drag' around a rectangular selection of objects
2) Then change the selection option to the 2nd option.
you can now target a (any of the) selected object and 'click/tap and drag' to relocate that group of objects
Alternative (to the rectangle selection) you can go straight to the 2nd option and single click/tap on objects to mark them for action.
Once all the required objects are select, pick any one and "click/tap and drag'
#3 Posted : 01 October 2023 12:59:14(UTC)
You can also divide up the layout into more than one section, so you don't see the entire diagram on one cramped screen.
This page was generated in 0.217 seconds.
