Offline einotuominen
#1 Posted : 20 September 2023 19:57:15(UTC)
einotuominen
I’ve been wondering what is the difference between DC motor types ”soft” and ”hard”?
5. ”Hard” is the default one which I always use, unless the motor has bell armature. What is the case when I should use the ”soft”?
Thanks!
-Eino
Edited by user 21 September 2023 06:11:12(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by einotuominen
#2 Posted : 21 September 2023 15:32:25(UTC)
Hard wasn't used to describe the first generation CSine motor.it was a vertical rotor. The soft drive is a can shape either driving gears or cardan shafts.
#3 Posted : 21 September 2023 15:50:18(UTC)
"Hard" and "soft" are presets for the load regulation. I guess you can get similar results with both presets if you fine-tune the other parameters.
As I understand it, "hard" is a good option for motors with small or no fly-wheels while "soft" might be a better option for locos with large fly-wheels.
I'd try both "hard" and "soft" and also "c90" for all motors (even motors that are not "c90") to see which gives the best results.
Then you can try to get even better results with fine tuning.
BTW: The "soft" setting has nothing to do with the "soft-drive sinus" motor - there is a different setting for sinus motors.
This page was generated in 0.373 seconds.
