Offline heinrichhess
#1 Posted : 14 September 2023 15:46:12(UTC)
heinrichhess
just planning on setting up train time tables on analogue signals system using 4 platforms optical illusion witch is a revers loop of witch i have found a plan for online and will hold a train hidden in back of station
Really need to plan train departure times so no overlapping have not sorted that out think prime numbers are the key. Thinking of using a time delay relay on isolated track not Shure if it can Handel ac power would like to see the time best thing to date is this led display how ever for me will probably end up with old alarm clock would like old clock face
any help would be grate
hess
Offline Stefano Rocca
#2 Posted : 14 September 2023 21:12:36(UTC)
Stefano Rocca
Sorry, dear Heinrich,,,,your english doesnt have sense....are you sure to be a UK citizen? I can't understand at all your question!
Stefano Rocca
thanks 1 user liked this useful post by Stefano Rocca
#3 Posted : 14 September 2023 22:52:23(UTC)
heinrichhess
Stefano Rocca
i what trains to stop in station for set time then pull out
hess
Offline Michael4
#4 Posted : 14 September 2023 23:26:07(UTC)
Michael4
If analogue layout you need Marklin 6600
#5 Posted : 15 September 2023 11:20:11(UTC)
heinrichhess
would be a grate option how ever i am using delta sill think an alarm clock will be best option
hess
#6 Posted : 15 September 2023 14:45:06(UTC)
Stefano Rocca
You're right, dear Hess....unfortunately you can't use the 6600 with delta or digital locos.
Stefano Rocca
hess
#7 Posted : 15 September 2023 15:29:27(UTC)
heinrichhess
same idea just add track power
hess
#8 Posted : 15 September 2023 15:31:52(UTC)
Stefano Rocca
Tend to agree. I can’t follow what this is about. Is it trains leaving stations at certain times without running into each other. I use the CS3 and routes can be set with trains leaving at different times but I really don’t understand what is required.
#9 Posted : 15 September 2023 16:17:17(UTC)
heinrichhess
yes Is it trains leaving stations at certain times without running into each other. with out CS3
This page was generated in 0.546 seconds.
