2 Pages12>
Offline GSRR
#1 Posted : 11 March 2009 01:13:07(UTC)
GSRR
I'm wondering if anyone has heard of this software, and used it?
TouchCab
The flagship product - an application that turns your iPhone or iPod Touch into a handheld throttle for your model railroad.
http://www.touchcab.com/
(I did a forum search and found no mention of this)
Thomas
Edited by user 23 February 2012 20:49:39(UTC)  | Reason: Not specified
#2 Posted : 11 March 2009 01:58:39(UTC)
I think it has been discussed before. Somewhere there is a video of someone who did this.
Offline Frostie
#3 Posted : 11 March 2009 02:27:18(UTC)
Frostie
I brought it up when I first purchased my I phone and discovered it's finctionality.
Great idea, but waiting to see how you can interface Iphone into CS2
CS/MS Digital Era 1/2
Offline GSRR
#4 Posted : 11 March 2009 06:59:39(UTC)
GSRR
I found the video. I believe he wrote something for his Java enabled mobile phone and is using the mobile network to "communicate" I even read of people using a program with their cordless landline phone? Also saw the post where Dale uses his Windows Pocket PC.
What interests me is that that TouchCab is a commercial product, and comes in 2 flavors. Free version gives you some limited function, and for $7.00 USD on the iTunes Store you can purchase the unlocked version that has both throttle and track control. This also works off of a WiFi connection, no messing with mobile networks, (and the resulting fees). Also it works with an iPod Touch and it's WiFi connection.
Hopefully someone with a CS2 can test it out, but I'm looking for the developer to maybe connect to the Mobile Station also, if it is feasible.
Regards.
Thomas
#5 Posted : 11 March 2009 11:14:05(UTC)
Is using this connection satisfying some electronics hobby urge? That is perfectly OK.
Like climb a mountain, because it is there to be climbed?
Because everything you need to control the trains is already in the CS, CSII and MS.
Offline Frostie
#6 Posted : 11 March 2009 14:47:49(UTC)
Frostie
The problem with the MS is it requires a wired connection. A true mobile controller should be wireless. That is a major flaw with the new MS2.
Maybe they are redesigning it to be truly mobile.
Offline jeehring
#7 Posted : 11 March 2009 15:18:00(UTC)
jeehring
Mistral , which is a small MRR manufacturer ( belgian/French) , has made available an "electronic circuit board" to be installed inside their model in such a way you can drive it and activate sounds on an analog layout from a Nokia mobile phone...
#8 Posted: : 11 March 2009 15:34:21(UTC)
Views messages in topic : 15,870
What happens if the phone rings when you're running your trains? Does it stop everything?
Offline TouchCab
#9 Posted : 11 March 2009 20:14:49(UTC)
TouchCab
[size=1" face="Verdana" id="quote]quote:Originally posted by GSRR
<br />I'm wondering if anyone has heard of this software, and used it?
TouchCab
Umm ... yes, I have heard of it wink
When the phone rings, TouchCab does what any iPhone app does - it quits (after disconnecting).
The trains keep running, since they are controlled by the command station. If your layout allows you to stray far from the command station, you should set the iPhone in airplane mode, so it doesn't ring while you're busy running trains.
I'm looking into the CS2, but I haven't found a decent protocol specification yet. If anyone knows where to find it, I'll look into it. The CAN specification does not look like it's very useful for network control.
If there is anything else you want to know, I'm here.
Jens
This account is no longer active
#10 Posted : 11 March 2009 20:48:18(UTC)
Jens, you are forcing me to get an iPod Touch.... It works with that too, right?
Offline TouchCab
#11 Posted : 11 March 2009 21:03:48(UTC)
TouchCab
Yes, it works on an iPod Touch.
I had a second look at the CS2 protocol, and it must be my horrible skills in the German language that fooled me at first.
It should be possible, but the connection looks a bit awkward. As I read it, the IP address of the CS2 must be set in the connected network device/computer as usual, but the IP address of the connected device/computer must also be set in the CS2 ?
Hmm ... does anyone know more?
Jens Vesterdahl
Jens
#12 Posted : 11 March 2009 21:16:02(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by TouchCab
<br />.. but the IP address of the connected device/computer must also be set in the CS2 ?
Not correct.
You need to tick/check the "Start Gateway" box in the &gt;setup&gt;ip section but after that any device (local subnet) listening on 15730 will see the broadcast data.
Offline TouchCab
#13 Posted : 11 March 2009 21:27:30(UTC)
TouchCab
Oh, okay - thanks for the clarification.
However, CS2 support is not right around the corner. I have an ECoS and a Central Station 1, but right now TouchCab needs to earn some money back my way before I can afford a CS2 Smile
Jens
Offline GSRR
#14 Posted : 11 March 2009 21:53:20(UTC)
GSRR
<br />Is using this connection satisfying some electronics hobby urge? That is perfectly OK.
Kimball,
For me I'm seeking out alternatives. I'm at the jumping point where I may get further into digital with encoders and such. When M* announced the upgraded Mobile Station 2, I was ready to leap. The CS2 I think is to much for what I need. Now that the MS2 is delayed at least until 2010, I'm looking elsewhere.
If it is feasible for me to install LocCommander on a readily available computer in my house, and if it can "talk" with my available iPod Touch that I have already for work, then I'm interested. The barrier to entry to "full" digital is much less than a CS2.
And yes it just fun to play with the Ipod. wink There are now more than 25,000 applications for the iPhone. I use more than 10 for work alone.
Thomas
Offline GSRR
#15 Posted : 11 March 2009 21:55:27(UTC)
GSRR
[size=1" face="Verdana" id="quote]quote:Originally posted by Frostie
<br />The problem with the MS is it requires a wired connection. A true mobile controller should be wireless. That is a major flaw with the new MS2.
Agreed. The MS2 looks to be a good thing, at least on paper. Better if it was wireless.
Regards.
Thomas
Offline GSRR
#16 Posted : 11 March 2009 21:58:06(UTC)
GSRR
<br />Jens, you are forcing me to get an iPod Touch.... It works with that too, right?
Juhan,
The 8gb iPod Touch can be had for $200 USD. wink
Regards.
Thomas
Offline GSRR
#17 Posted : 11 March 2009 22:08:06(UTC)
GSRR
TouchCab
Jens,
Thank you for joining the discussion. Nice to have the developer on board. Smile
Would your program potentially work with a Mobile Station? Also have you seen the LocCommander program here on the forum? Could TouchCab work with that?
Regards.
Thomas
Offline TouchCab
#18 Posted : 11 March 2009 22:54:49(UTC)
TouchCab
Regards.
Thomas
Happy to be here.
iTunes may be a convenient sales channel, but user contact sucks big time.
I get to see the reviews of the local store, but no international reviews. Denmark is a very small country, so I need to go through unofficial back doors to see what people say about the product elsewhere in the world, and even then I can't talk back.
This is what I was looking for.
As for MS2 (or any other device for that matter), if it does not have a network connection, TouchCab will not support it. If a device has a network connection and a decent and available protocol, it will be considered.
I don't know LocCommander, but mobile devices connecting to the layout through an application on a computer has been done. LocCommander should then be able to accept incoming connections, and a communications protocol must be defined.
As you may have read on the home page, TouchCab's mission is ease of use and to improve the user experience in the world of model railroading. Messing with IP numbers is not considered ease of use in my book - that's why I frowned at the CS2 setup before clapcott kindly set the record straight.
I have been talking to ESU about using zero-configuration networking, and they seemed interested. I hope version 3.0.0 of the ECoS and CS1 will implement it, but I don't really expect it until a later release. Time will show.
Perhaps I should try talking to Märklin also, to see if they're interested.
Anyway, I am extremely picky about how TouchCab can be connected. It should be easy, simple and straight forward. If the user at any time goes: "Now what?", I didn't do my job right.
Jens Vesterdahl
Jens
Offline fvri
#19 Posted : 12 March 2009 20:37:57(UTC)
fvri
Collaboration between TouchCab and any other MR SW 'client' application running on a PC could be possible when a protocol is defined as Jens stated.
But ... as TouchCab and any other MR SW application running on a PC are client applications connecting to a digital control system running a server application, data exchange could be simply done via the server application when it sends 'events' after commands(setting train speed, triggering functions, etc) are initiated by one of the client applications. As far as I know only feedback occupancy events are triggered by the server application.
BTW. I have been developing a client application (iLoc) that could run on a PDA communicating with the LocCommander (server) application on a PC. But I have stopped this development... as better things like TouchCab came along.
(User friendly configurable) Connectivity is certainly an important issue! Keep on the good work Jens!
These handheld devices running a client application controlling a MR layout have their values but I still prefer controlling directly via the digital system or a client application running on a PC. Seeing and acting on a representation of your MR layout on a big display is for me still preferable.
BTW. no plans to support CS2 in LocCommander, I'm using an ECoS and 6021...[:I]
Frank
#20 Posted : 12 March 2009 22:45:50(UTC)
I suspect the new generation of netbook computers running Linux or Windows will become good potential platforms for running remote train controllers. At present my PDA with wi-fi connectivity to my home network works perfectly, but if my PDA hardware dies I will not spend the money on a new PDA when $300 can buy a fully functional netbook with a bigger screen, gobs of memory and disk space.... granted the PDA does have a touchscreen, but the full keyboard will probably work well with good UI design.
Offline Mafi
#21 Posted : 12 March 2009 23:07:03(UTC)
Mafi
<br />...but the IP address of the connected device/computer must also be set in the CS2 ?
Hi Jens,
CS2: you can set both your application and the CS2 to listen and send data to the subnet's broadcast IP, so it is easier than connecting to a CS1/ECoS.
For a testing application (MacOS-X, Win, Linux) checkout this:
http://c2xh-mafi.npage.de/
You can setup your Macintosh to send data to the broadcast-IP using UDP simulating the CS2 (for example: SimpleDigitalLocomotive will send the same data like the CS2 would do, just exachange the Ports). You will not need a real CS2 for the first steps of connection testing.
Good to see another Mac-Developer around here!
Mafi
http://simpledigitallocomotive.npage.de/
EDIT 2014: links updated
Edited by user 28 August 2014 19:41:19(UTC)  | Reason: Not specified
Don't be too proud of the new high tech terror you just have invented! (Darth Vader, Episode IV)
Offline TouchCab
#22 Posted : 13 March 2009 23:08:36(UTC)
TouchCab
[size=1" face="Verdana" id="quote]quote:Originally posted by Mafi
http://www.sdl.claranet.de/C2XH.zip
I realize the CS2 protocol (CAN) is much more versatile than it looks at first glimpse, so for me (and TouchCab) CS2 is now a viable option.
I have downloaded the C2XH application, and I'll look into it. Seems like a great tool Smile
BTW: If you'd like to see my steam locomotive pictures, they're at: http://damplokomotiver.touchcab.com.
It's all in Danish, but from top to bottom, the 1:1 menu is:
DSB = Danish State Railways
"Litra" means class, so there are some sections about several classes of the DSB.
Museumstog = The Danish Railway Museum and the live division
Fra Førerhuset = From the cab (I'm a fireman, although not active anymore)
Rodekassen = Misc
Udlandet = Abroad - steam I encountered on travels
Cumbres & Toltec = 'nuff said
Overlevende = List of surviving Danish steamers
Have fun!
Jens
#23 Posted : 14 March 2009 09:19:46(UTC)
Welcome to the forum, TouchCab.
Offline hwestl
#24 Posted : 17 March 2009 13:26:29(UTC)
hwestl
I did something like this 2007, with a program where I used a Sony Ericsson mobile phone to control the CS1. The difference is that I used the phone network and not the WiFi. But the procedure is the same, using socket with IP address and port no. Which is also the same as for any computer, laptop or desktop on your home network.
It shouldn't be any big differences how to connect to the CS2, only the commands to run the loc will probably differ (I haven't checked the CAN protocol, cause I have no CS2)
You can watch a video I made at
Offline dntower85
#25 Posted : 17 March 2009 15:14:57(UTC)
dntower85
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
<br />I suspect the new generation of netbook computers running Linux or Windows will become good potential platforms for running remote train controllers. At present my PDA with wi-fi connectivity to my home network works perfectly, but if my PDA hardware dies I will not spend the money on a new PDA when $300 can buy a fully functional netbook with a bigger screen, gobs of memory and disk space.... granted the PDA does have a touchscreen, but the full keyboard will probably work well with good UI design.
Dale - get an i-phone instead and down load there app kit and build an interface for the IB. since nobody has an iphone app for that.
DT
#26 Posted : 04 April 2009 00:38:54(UTC)
Hrrrmm... Well...
An iPod Touch just happened to follow me home from a store today... It just said "buy me, buy me, I am mrr related..."...
Have also downloaded the free version of TouchCab...
Guess I will just have to build up an oval this weekend, connect the CS1 to the home network and try the concept...
That iPod is a quite fun gadget by itself, and of course I have already tried to read the forum with it, as well as watching Top Gear downloads...
Offline GSRR
#27 Posted : 04 April 2009 02:08:27(UTC)
GSRR
<br />Hrrrmm... Well...
Juhan,
Congrats and enjoy! It is quite a useful tool even without the phone portion. I downloaded Skype the other day, which is very handy.
For anyone who wants to have a try at building an application for the iPhone Apple and Stanford University have joined forces to provide free tutorial on iPhone application development via iTunes. More here:
http://blog.wired.com/ga...9/04/apple-stanford.html
Thomas
Offline TouchCab
#28 Posted : 04 April 2009 21:49:47(UTC)
TouchCab
Enjoy! Smile
Jens
Offline Chriscam
#29 Posted : 05 April 2009 08:40:57(UTC)
Chriscam
Has anyone with an Ecos that is updated to the new 3.0 software tried Touchcab yet? I am using Touchcab now but have not updated my Ecos to 3.0 yet.
The FAQ on the Touchcab site says "The immediate plan is to support ECoS 2 (#50200), ECoS 1 version 3.0.0 and Central Station 1 update 3.0.0, when these are relased from ESU. " which seems to say that it does not/may not work with 3.0.
Chris
Offline TouchCab
#30 Posted : 05 April 2009 15:43:26(UTC)
TouchCab
[size=1" face="Verdana" id="quote]quote:Originally posted by Chriscam
<br />Has anyone with an Ecos that is updated to the new 3.0 software tried Touchcab yet? I am using Touchcab now but have not updated my Ecos to 3.0 yet.
Chris
It should work.
I'm in the middle of a development process for 1.1.3, and I don't want to update my ECoS to 3.0.0 yet as it's a one way street.
The protocol spec for ECoS 3.0.0 has not been released, but I have not seen anything that indicates TouchCab should not work with this version. It just hasn't been tried yet, so I can't go out in public and say that it works for sure.
Jens
Offline Chriscam
#31 Posted : 05 April 2009 22:08:42(UTC)
Chriscam
Great, thanks for the quick reply Jens. And thanks for a great app - keep up the good work! Chris
Offline TouchCab
#32 Posted : 07 April 2009 13:31:58(UTC)
TouchCab
Correction ... on my way through the code I have noticed that TouchCab will not work with MFX locomotives or decoders. This will be fixed in the next version of both TouchCab and TouchCab Free.
Jens
Offline TouchCab
#33 Posted : 28 April 2009 23:03:05(UTC)
TouchCab
I can now officially say that TouchCab works with ECoS v3.0.0, except for the glitch with mfx and M4 locomotives (aargh!!)
This will be fixed in the next release (v1.1), which is now feature complete. I'm fiddling with some cosmetics before a thorough test and then it's off for review. Within a few weeks, I'd say.
Jens
Offline GSRR
#34 Posted : 29 April 2009 02:11:05(UTC)
GSRR
Jens,
Thanks for the update.
Thomas
Offline TouchCab
#35 Posted : 08 May 2009 01:08:29(UTC)
TouchCab
For the record, TouchCab and TouchCab Free version 1.1 have now been submitted to Apple for review. If all goes well, they should be available on the App Store within a week or so.
Jens
Offline GSRR
#36 Posted : 19 May 2009 16:42:05(UTC)
GSRR
<br />For the record, TouchCab and TouchCab Free version 1.1 have now been submitted to Apple for review. If all goes well, they should be available on the App Store within a week or so.
Jens,
I saw the update last night in iTunes.
Thomas
Offline TouchCab
#37 Posted : 04 November 2009 23:33:45(UTC)
TouchCab
Hello all.
Time has passed since this thread went silent, but now I have a video of TouchCab in action on a gauge 1 layout in Copenhagen last weekend.
Unfortunately the turnouts are not yet connected to the ECoS, but replace the ECoS with a CS1 and it's "on topic" for this forum.
Enjoy:
Jens
#38 Posted : 05 November 2009 00:10:28(UTC)
I was there and did saw it...!!!
Works perfect!
But to expensive as the hell!!! [}:)]
Better to buy an ZIMO cabcontrol radio instead... wink
biggrin
#39 Posted : 05 November 2009 04:19:16(UTC)
I tried all the links and searched the Apple store, but I can't find TouchCab...
Offline TimR
#40 Posted : 05 November 2009 04:58:57(UTC)
TimR
Indonesia
Great video and excellent demonstration!
Thanks!
I have a question regarding how it work though;
Does your iPhone effectively become a third locomotive controller?
Perhaps to put it another way around;
Can you still take control of two more locomotives through ECoS or CS1 through the two halves of the screen; while controlling another through the iPhone?
Or would it be that while controlling a lok through this application - one half of ECoS or CS1 screen would be showing to be "occupied"?
I hope you understand my question...
Thanks again
Now collecting C-Sine models.
Offline Fredrik
#41 Posted : 05 November 2009 12:46:30(UTC)
Fredrik
there's no problem in controlling 2 other locos from the CS/ECoS in combination with TouchCab!
There's also no problem reaching the TouchCab in the AppStore using an IPhone...! (just tried)
Fredrik.
WWW: MJ-fjärren
Offline TouchCab
#42 Posted : 05 November 2009 21:43:36(UTC)
TouchCab
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
TouchCab is expensive ???
Jens
Offline TouchCab
#43 Posted : 05 November 2009 21:45:52(UTC)
TouchCab
<br />I tried all the links and searched the Apple store, but I can't find TouchCab...
It's not the Apple Store.
You need to have iTunes installed, and in there, you go to the "app store".
(app and Apple - easy to misunderstand, I know)
Jens
#44 Posted : 05 November 2009 21:54:14(UTC)
I have the free version on my iPod Touch - just too lazy to connect the CS1 to the home network...
The iPod was bought earlier this year (see earlier post) but not used so much at all... I have to admit, I am a gadget freak... biggrin
Perfect format as a mrr controller with TouchCab, which is a very easy to use software... Great work, Jens!
Offline TouchCab
#45 Posted : 05 November 2009 21:57:23(UTC)
TouchCab
[size=1" face="Verdana" id="quote]quote:Originally posted by TimR
Yes.
TouchCab does not block one controller. From TouchCab you may take over a locomotive which is controlled by one of the controllers in the CS/ECoS, but then just select a different loco for that controller.
(Gee - what a lot of controllers in that text. Can you control the controlling controller ... aargh!)
Jens
Offline TimR
#46 Posted : 05 November 2009 22:21:19(UTC)
TimR
Indonesia
So effectively, the application turns an iPhone into a more versatile and expensive version of MS... SmileSmile
Thanks, Jens
I think MS2 have another strong contender in the market now....wink
Offline TouchCab
#47 Posted : 05 November 2009 22:38:52(UTC)
TouchCab
<br />So effectively, the application turns an iPhone into a more versatile and expensive version of MS... SmileSmile
Yes, but if you want a cheaper version, TouchCab works on an iPod touch also.
I like to think so, yes biggrin
Jens
#48 Posted : 06 November 2009 15:53:39(UTC)
I have the iPod touch and have downloaded the full version of touchcab.. As soon as I can claw the iPod touch from Miss 10's death grip, I will fire up the eCOS and test out the software..
#49 Posted : 08 November 2009 07:33:41(UTC)
Sigh.. The problem for me is that the PC, which is us for Windigipet is wirelessly connected to the router on a 192.168.1.xx address, while I connect the eCOS to the PC using the lan card which is a 192.168.2.xxx address and the eCOS has a 192.168.2.xxx address - effectively the PC is acting as a router and the iPod can't see the eCOS.. Any clues how I fix this one???
#50 Posted : 08 November 2009 07:37:36(UTC)
<br />Any clues how I fix this one???
Get an ethernet switch, they're not very expensive.
Guest (5)
2 Pages12>
This page was generated in 1.191 seconds.
