Offline SlowOrder
#1 Posted : 02 September 2023 23:00:55(UTC)
SlowOrder
Good afternoon,
Does anyone know what the part number is for the screws and washers that hold the old 7009 masts to their M track clip bases? Or if there is a cheaper metric alternative in bulk? We went to the hardware store earlier, and a regular M3 metric nut is too large. The diameter of the screw part on the mast itself is 2.7mm if that helps at all.
Edit: 2.0mm diameter.
Thank you,
Andy Bohman
Offline Toosmall
#2 Posted : 02 September 2023 23:21:16(UTC)
Toosmall
Try Element 14, even available down under!
https://au.element14.com/search?st=M2%20nuts
They even have stainless steel M2 Nyloc nuts.
This page was generated in 0.415 seconds.
