Offline heinrichhess
#1 Posted : 13 August 2023 18:51:57(UTC)
heinrichhess
trying to find out what a vapor storage tank engine is used for is it just reduced fire risk ?
hess
thanks 1 user liked this useful post by heinrichhess
#2 Posted : 13 August 2023 19:17:54(UTC)
Those fireless steamers can be used in chemical factories and similar facilities.
They operate with hot water and therefore are handy for factories that produce huge amounts of hot water anyway.
Offline Paul59
#3 Posted : 13 August 2023 19:24:14(UTC)
Paul59
Yes, it's a fireless loco - they were used a lot in industry where you need to avoid sparks or fire. Also in places where cleanliness is important and no smoke. The only emission is water vapour.
Places like oil refineries, chemical plants, paper mills, food factories etc etc.
The vessel is actually filled with superheated water and heavily insulated so as the steam is used and the pressure drops the water re boils since the boiling point will also drop. Provided there's water and a hot enough temperature the water will continue to boil and recover the pressure.
Rather like a large aerosol can.
Apparently they could actually run for several hours without having to be recharged. They could also be left standing for considerable time without using any 'fuel'. The vessel held a lot of water as is had no flue tubes or firebox taking up space as in a conventional steam engine. They could also be driven single handedly and required no special training regarding boiler management as a normal steam engine would. Most large factories or plants had a ready steam supply for other purposes so recharging was quite easy and convenient.
Safety was also a plus point as there was no fire - if the water level was run down too low they simply ground to a halt.
I think some are still used today.
Marklin HO using M track. Now reverted to analogue as I find it has more character - and I understand it!
thanks 2 users liked this useful post by Paul59
#4 Posted : 13 August 2023 21:57:42(UTC)
I remember having read an anecdote about fireless locos working in steel mills; Sometimes when the heat/pressure was running out before anticipated, the crew would -illegally- throw a glowing iron-rod into the kettle, which would then generate enough steam for the rest of the day... (¿?)
#5 Posted : 13 August 2023 22:44:50(UTC)
heinrichhess
so they must be yard shunters as you could not refuel on the move will be grate for my v2 factory
hess
#6 Posted : 14 August 2023 14:04:08(UTC)
True, unless a steam generating plant was on the main line.
Offline kiwiracer
#7 Posted : 16 August 2023 05:34:34(UTC)
kiwiracer
Here are some photos of a fire less loco in Rheinfelden, Switzerland.
The Loco is now displayed on a roundabout in front of a new housing development being undertaken in the area near the old brewery site.
My understanding is that it was from the Salmen Brewery and was used around the brewery and to take product to and from the Rheinfelden station (about one to two km away), on the Basel Zurich line.
Cheers Brett
Don't dodge difficulties, meet and defeat them. (Anon)
Anyone can eat an elephant, one bite at a time (Anon)
thanks 3 users liked this useful post by kiwiracer
This page was generated in 0.497 seconds.
