Offline French_Fabrice
#1 Posted : 03 August 2023 15:14:04(UTC)
French_Fabrice
Hello Fellow Markliners,
Having recently read some posts about fixing C track down (here), a number of replies have raised my attention about noise, and how to decrease it.
I have no expertise into that domain, and I'm thinking it can be a complex topic, which may not have a simple answer.
Furthermore, it may depends on many factors, like:
-room size and acoustics
-track type (M,K,C)
-single or multi-level layouts
-sensitivity of people to noise and/or expectation of people to listen to rolling trains
-...and probably much more
I've read until so far some advice, and sometimes they are contradictory.
What I can remember (to be confirmed):
-Avoid screwing the tracks on plywood, because screws transmit the noise to the board (and amplify it)
-Ballast (example: for K track) may add noise too
-Use some noise absorbing material below the tracks (and/or below the plywood ?), possibly multiple coats of different material
Questions I have in mind at the moment:
-If you use K flex track to design (large) curves without screwing them, how can it be possible to keep them firmly sealed on the board ?
I'm well aware that this is an extremely vast subject, and that it's likely to be a bit messy, at least at first.
The idea here is to collect various experiences, both positive and negative, and then try to sort them out, so that as many people as possible interested in this subject can benefit from them.
All contributions are welcome.
Fabrice
thanks 3 users liked this useful post by French_Fabrice
Offline heinrichhess
#2 Posted : 03 August 2023 16:19:59(UTC)
heinrichhess
french_fabrice hot glue would be best as it sets quick use a spot at ever curve change it will hold's very well if you need to readjust it you can just heat it back up also in my experience flex track is longer witch would Gateley help noise reducing yet to mention less joins
hess
thanks 2 users liked this useful post by heinrichhess
#3 Posted : 03 August 2023 17:13:28(UTC)
Woodland scenic underlay gives no noise running. Expensive but it works and lasts. I use copydex to fix it to the base and same to fix track to underlay. Just fix track every yard with a drop of copydex and you can still lift the track you wish.
thanks 4 users liked this useful post by David Dewar
Offline michelvr
#4 Posted : 03 August 2023 17:58:48(UTC)
michelvr
Hello French_Fabrice and fellow Marklin enthusiasts,
I have expertise on the the subject and here’s my opinion.
I have a large Marklin C track layout (45’ x 12’ or 13.72m x 3.66m) with over forty five turnouts. Build on a frame using L girders with risers connected to a plywood subroadbed. Not sure what L girder benchwork is just Google it please. All my Märklin C track’s are screwed using the C track screws.
I must state as a fact that the noise is acceptable and adds to the reality of the prototype. If you have forgotten what a passing train sounds like go out and explore the real work! Go to the nearest railroad and hear the real thing for yourself, it’s blinking LOUD. The noise is a part of the enjoyment of the hobby, so enjoy and have fun.
thanks 5 users liked this useful post by michelvr
#5 Posted : 03 August 2023 22:12:05(UTC)
Like Michelvr, I believe screwing C track on plywood (my case 10 mm thick) causes no problem at all provided:
- you don't use a large piece of plywood (you want to avoid the drum effect
- you rather use rail support (the shape of rails plus 2 cm ) supported by the frame (transportable modules) and wooden traversers
- noise is significantly reduced as soon as you add landscape (grass, houses, walls, tree, etc) which in effect are noise dampened
Because I use Rocrail, all my locos (sound MFX) are powered (no insulated stop sections) meaning that there is a small residual sound when having many locos (28 my case on the layout). This residual sound is noticeable but rather discreet and eliminates rolling sound.
Exception: what I say is contradicted when you have sheet metal wagons and old locos (CCS800, DL800, G800 in my case) which I keep in boxes and showcases.
Offline Toosmall
#6 Posted : 04 August 2023 00:47:42(UTC)
Toosmall
I have used a lot of these products in my car (Australia). Butyl, foam of all thickness 3mm to 25mm (25mm from a ship chandler).
It was a lot of work reducing transmission & absorption, mostly used foam filling up every cavity. Not that the car was noisy to start with. It was a project that got out of hand.
Haven't used them on my layout as I built it decades ago.
Don't forget the room itself, acoustic absorption at ear level around the room will help. Can even be behind acoustic artwork canvas custom printing.
https://www.carbuilders.com.au/
Ceiling now has another 25mm of engine bay acoustic foam, reduced noise levels a lot.
Also replaced all the trim panel clips to also help reduce noise transmission.
All these same things will apply to a train layout. It will be a whole suite of solutions & a lot of time.
thanks 4 users liked this useful post by Toosmall
Offline Mark5
#7 Posted : 04 August 2023 16:21:31(UTC)
Mark5
How shall we achieve the sounds of silence?
I have been thinking a great deal about this topic lately. I live in a 1950s Montreal duplex above another family that can hear us if we walk heavy, jump or dance. My girls have learned to tip toe at night instead of walking on the balls of their feet.
So as we were dismantling our old show layout, I was reminded of the not-so-successful dampening methods I used when securing and ballasting M-track. I used a thin layer of 3/32 foam under the track glued to the drum-like plywood sheet along with the so-called rubber sound absorbers. All of this was rendered almost inert since the track was still screwed down through the rubber sound absorbers and then fixed firmly to the ground by ballasting the edges of the track which was firmly in place with watered-down white glue. I say "almost inert", since if I compare that to my boyhood layout on a straight up 1/2" 4x8 plywood sheet over solid benchwork, I remember that it was so loud that family would never let me run my trains when the television was on (it interrupted) or when rest was needed.
So I can affirm that some thin foam helped somewhat and especially with landscaping of hills with styrofoam around it, but you could certainly hear when the trains were in the tunnels, which told you when they were coming.
My plans with our new layout include screwing shelf style modules to the walls, HOWEVER, I will be using pieces of rubberized foam mats, the kind that is used for children's play areas, in between the wall and the wood, then the screws will not go into the wood but rather a drilled hole, then I will used a foam "washer" on the side of the screw head; what I mean here is that the benchwork is not screwed in; it will be sandwiched by a sturdy foam clamp that will reduce transmission of sound through a hard wood to dry wall connection. So you might ask: why not have your modules on legs with hard rubber wheels? Well in my shelf layout, we'll have a wood cover over when that part is not in use as part of it will be going into a higher traffic area of the hallway. If it is bumped by hips then boom, over go the trains and we would have train wrecks.
I will be reading any other suggestions here with keen interest. We are using C-track in the shadowlands and K-track in visible areas. I may use cheap white caulking at points on the C-track and lay it over some kind of foam, but not decided what would be best for us. Hoping to get a better grasp on Rocrail to keep my wiring underneath to a minimum, but if I eventually use under the layout tortoises and for my K switches and screwed down metal Sommerfeldt posts, then that's another layer of rigidity. I may try using my foam washer idea for posts.
How to avoid hard ballasting is something I can't seem to figure out.
I certainly would not want loose ballast. Not a huge fan of the Merkur foam ballast, because I would still end up using some gravel ballast and weathering the Merkur, however I may try it and see if I can get the effect I am looking for. That said the Merkur cost is prohibitive.
Another thing I learned from extremely noisy shows with multiple layouts:
Turn down or off your sound loco settings!
The racket for 7 hours can drive one mad.
I have noticed that subtle loco sounds are really nice.
People visiting say, "hey wait! I heard something" and then stoop down closer to the loco as it passes and are delighted with what they discover.
Onward to layout perfection,
Mark
thanks 2 users liked this useful post by Mark5
#8 Posted : 05 August 2023 01:34:30(UTC)
Views messages in topic : 4,037
Sorbasite sheets?
Offline MKOpSeattle
#9 Posted : 06 August 2023 07:12:26(UTC)
MKOpSeattle
I find this video from MarklinofSweden very helpful.
Reduce track noice Low cost
thanks 4 users liked this useful post by MKOpSeattle
#10 Posted : 09 August 2023 08:20:17(UTC)
Using risers for track width road bed (based on an L girder or similar framework) will not create anywhere near the noise levels of large flat sheets of plywood or MDF.
My C track layout is based on flat sheets and I do not screw or glue at all and any noise is acceptable.
#11 Posted : 17 August 2023 17:58:29(UTC)
French_Fabrice
Hello Friends,
Well, as expected, there are different replies, some depending on each person sensitivity and expectations.
Thanks to all of you having shared their experience.
From your answers, I like the use of the Woodland Scenics track-bed the most. https://woodlandscenics....ry/HOScaleTrackBedSystem
I think I'm going to order a pack of strips and do some tests...
As my layout is already built, the intensive use of such track-bed, if successful, will be for the next layout BigGrin.
In the past, I've also tested the solution provided by "Martin T", I mean the rug underlay from Ikea, named STOPP FILT.
I wasn't convinced by this material, but it is a matter of taste as usual. However, it is cheaper than WS track-bed...
Feel free to post other experiences, so that as many people as possible can benefit from them.
Fabrice
thanks 6 users liked this useful post by French_Fabrice
This page was generated in 0.420 seconds.
