Offline auntmartha
#1 Posted : 12 June 2023 16:32:32(UTC)
auntmartha
For various reasons I am building a small 90x160 cm layout
using old-style center rail M-track - I plan a similar one with
M-Puko-track and might do others as well.
The layout is in 2 modules to facilitate storage and transport.
Weight and cm3 are key factors.
Layout is completely analog - not a decoder in sight.
The old trafos are rather heavy.
I thought about having a cheap small SMPS installed under each layout,
with easy connection with extension wire to wall socket.
On the layout - next to the blue control boxes - would be a
pot-knob and a button to get a 24 Volt spike to change direction.
Is this feasable ? I'll insulate the SMPS properly - at least the 230V end
PS - this has been cross-posted at the Bar&Grill maillist.
Yours sincerely / Mit freundlichen Grüßen / Bien cordialement
Mr. Christian Vinaa
http://www.vinaa.dk/trains
...... Meanwhile, aunt Martha, having taken a tramp in the woods,
is lying in a ditch at the edge of town .........................
thanks 1 user liked this useful post by auntmartha
Offline ccranium
#2 Posted : 13 June 2023 18:06:16(UTC)
ccranium
Hi Christian,
I can't speak to the SMPS, etcetera, but have you considered using 6647 and/or 6629 for running the M track? They're smaller and lighter than the older trafos. You could even spread the load out with a 6002 for lighting and solenoids if needed. 6647's and 6002's seem to go for ~EUR30 each on eBay. 6629's are rarer and the shipping for the Sold ones is more than the recent prices for the trafo!
Best wishes from another M-track analog fan!
Brian
This page was generated in 0.462 seconds.
