Offline sricharanv
#1 Posted : 01 May 2023 01:24:31(UTC)
sricharanv
Good day everyone. I am new Marklin user and while I started with digital layout I have decided to convert to Analogue. I purchased used M-track which seems to be in OK condition(a bit of surface rust). I have also purchased old-style left switches (5038) and have connected the yellow wire to the yellow on transformer and have the two blue wires to the 7072 control unit and have the brown wire from the transformer brown to the 7032. The switching works and I also see the light lights up however there is a fundamental issue which is when the train go over the switcher, it stops. This is because there is no power on the middle rail. I have used a transformer and I can see the tracks connecting the switcher on either side have good voltage reading except the switcher itself. Please see the attached images. I am not sure what I am missing. I could not find any manual when I searched for 5038 manual. Any help is greatly appreciatednon-switcher-track.jpgswitcher-track.jpg.
Thank you,
Charan
Offline Henrik Schütz
#2 Posted : 01 May 2023 09:15:43(UTC)
Henrik Schütz
That is a 5203 switch, try to clean the studs, somtimes the are covered with dirt.
Henrik
thanks 1 user liked this useful post by Henrik Schütz
Offline ccranium
#3 Posted : 01 May 2023 17:42:47(UTC)
ccranium
Henrik
Also give the outer rails and the three center rail tabs a thorough cleaning, even the tabs on the adjacent track sections. I've bought many used M turnouts with the same problem and the amount of goo is phenominal on some of them. I use CRC QS Contact Cleaner carefully sprayed into the can's cap, and then lots of soaked cotton swabs until they come up white from all parts. Sometimes the pikos are set too low and the loks stop, but your voltage indicates dirty connections somewhere.
Home Depot carries the CRC cleaner.
Offline sricharanv
#4 Posted : 02 May 2023 02:58:54(UTC)
sricharanv
Thank you Ccranium and Henrik for your responses. I'll clean them up and test again.
This page was generated in 0.636 seconds.
