Offline blid
#1 Posted : 30 April 2023 11:28:54(UTC)
blid
Question. Will a step-up converter for 120V to 240V be OK to use for 3 Marklin 60061 60 VA power packs in the US? At least 200 VA will be OK for Amp and voltage. But what about the difference in frequency? 60 Hz v. 50Hz. Intended for a CS2 and two boosters 60174.
#2 Posted : 30 April 2023 12:25:09(UTC)
Hi xx (a first name would be great)
The 60061 is a high efficiency voltage converter that works from 230 VAC sinusoidal either 50 Hz or 60 Hz
If you use a transformer to change your (sinusoidal, 50or 60Hz) mains voltage into 230 VAC this will be OK
If you use a compact voltage converter, so called "travel adaptor" (high frequency, small transformer) then you are in totally unknown territory and you may end-up burning the 60061. I wouldn't recommend it
Offline blid
#3 Posted : 30 April 2023 12:44:03(UTC)
blid
Thank you Jean.
Offline nhumps
#4 Posted : 01 May 2023 07:04:50(UTC)
nhumps
As noted the 60061 is expecting a particular input voltage of 230V at 50-60Hz. While you should be ok if you can match that I agree with Jean and be too nervous using a step up/adapter myself.
Have you considered the purchase of a 60045 ?
https://www.maerklin.de/...ts/details/article/60045
The 60045 is built to accept 100-240 Volts. 60041, 60042, 60043 and 60045 only differ on the adapter plug for their respective markets.
Offline blid
#5 Posted : 01 May 2023 12:22:50(UTC)
blid
Thank you nhumps. I know about the 60045 but the three 60061s are available for free. I now have a picture of the label on the 60061 and it clearly states 50 – 60 Hz. A step-up transformer will be the cheapest way.
thanks 1 user liked this useful post by blid
#6 Posted : 01 May 2023 13:20:02(UTC)
I would try plugging the 60061 into 110v. You won't hurt it, but I believe it will run satisfactorily. I think you will find that the only reason that it is marked for 230V is because of the plug on it, and that the 110V version is the same inside, just a differenct plug on the end of the cord. It is a long time since I have seen a switch mode supply that wasn't capable of running on 100-230V as the wide input range is practically ubiquitous these days, and it doesn't make sense for the manufacturer to stock two different boards when one will do.
Offline blid
#7 Posted : 01 May 2023 13:56:09(UTC)
blid
I will forward this information. Thank you kiwiAlan.
Offline nhumps
#8 Posted : 02 May 2023 00:24:38(UTC)
nhumps
Perhaps as an aside the 60065 is the model that is specified for input of 120V at 60 Hz and the manual has a warning about "INPUT : 120 VAC, 60 HZ ONLY."
It's curious that the the manuals for the 60065 and 60061 differ with regards to warnings. Also it's a source for the label on the power supply.
60065:
https://static.maerklin....286d811c941434542065.pdf
60061:
https://static.maerklin....fbc255d5bc1475161856.pdf
thanks 1 user liked this useful post by nhumps
Offline dickinsonj
#9 Posted : 02 May 2023 01:44:56(UTC)
I believe that is mostly lawyer talk, which we get a lot of ihere n the US.
It would be idiotic to have different internals for switched mode power supplies which can easily handle a wide range of inputs. Only the mains plug needs to be market specific.
I believe that the manual entry is real, but I can't imagine anything beyond legal disclaimers being in play here.
This page was generated in 0.452 seconds.
