Offline PFG45
#1 Posted : 17 February 2023 20:56:03(UTC)
PFG45
After a few years of sitting idle my SBB 6/6 (37320) would not move an inch so I had my local dealer sending it to Märklin in Göppingen for repairs.
Apparently the decoder and the five pole motor had to be replaced.
Now, when setting up the double traction together with the Re 4/4 (37320) the acceleration and braking are not synchronous anymore as much as they were when I bought the double traction. I understand that the two locomotives were programmed for double traction at the factory.
I can get the two locomotives to run at the same speed but I cannot get them to accelerate and brate at the same pace. I have tried to reset settings to the factory settings but I believe that the new decoder is not set up for double traction.
I was wondering if anyone could share the factory settings of the 37320 locomotives or please point me to which settings (whether acceleration and brake settngs or cv-values/parameters or other ) I should focus on adjusting as I would like the locomotives to work as double traction again.
Any help or advice would be very much appreciated.
Søren
Offline dickinsonj
#2 Posted : 18 February 2023 02:02:13(UTC)
Hi Søren,
When I have had this situation I have walked through all of the CVs that I can access and compared the settings, making them match. I am not 100% sure that just matching the parameters at that level will fix this problem however and the factory decoders are locked and impossible to fix when the base software is not correct.
If you were to replace both decoders, build a project for them, and load that program onto both decoders, you could ensure that they are identical. But short of that I would be interested to hear other options for fixing this from the collective forum wisdom. ThumpUp
Locking the factory decoders was one of the worst decisions I have seen them make. Considering the price of current models they should have the best decoders available, not crippled, unfixable junk. I guess that means ESU and that is not going to happen.
Offline PFG45
#3 Posted : 18 February 2023 10:02:07(UTC)
PFG45
Thanks Jim,
I seem to recall that I checked the CV parameters out of curiosity when I bought them, and they did not entirely match. I presume that weight and other things such as gearing(?) may play a role. But, I will nevertheless start comparing the cv-values but not knowing exactly what each parameter does make it a bit cumbersome but you got to start somewhere. 😀
Søren
thanks 1 user liked this useful post by PFG45
#4 Posted : 18 February 2023 12:29:42(UTC)
Hi Søren
I may be totally off topic but seems to me the adjustment is not difficult doing so:
- make available a rail loop, free of other locos
- create a double traction
- make sure both locos have the same acceleration curve (linear, standard exponential, exponential,...)
- adjust first the speed of each loco by adjusting CV 5 on one of the locos
- once the speed is the same on both locos (your case), start adjusting the acceleration delay using CV 3
- when finished, adjust the braking delay using CV4
Notes:
- of course, you pick one of the locos as your reference and adjust the other one
- as Jim already said, CVs are dependent on the motor type, on the transmission (gear ratio), on decoder type mSD2, mSD3, etc. A simple duplication won't do in all cases.
- once both locos, when placed at each end of the loop, when subjected to various command using the double traction command behave similarly, you may couple them.
- double or multiple traction are not fit for use with isolated section from signals (risk that one loco stops while the rear loco keeps on pushing and may burn its motor. This is reserved to manual control or train software like Rocrail.
Here is a video on this subject
Rocrail note: there is a possibility to bring multiple locos to form a large multiple traction train and then start using the traction as a single loco and then , uncouple locos and start using them individually. Of course all this in complete automation but only when previously all their CVs have been adjusted as per above
Offline PFG45
#5 Posted : 18 February 2023 17:15:24(UTC)
PFG45
Hi Jean,
Thank you for reply and suggestions.
I will watch the video carefully later today/tomorrow.
The acceleration curve for both locos is the same - I am using Linear as that curve seems to give the closest initial performance.
I am using CS 2 but in order to do the subsequent adjustments to speed, acceleration and braking I just need to fully understand your reference to CV 5, CV 3 and CV 4. Are you referring to the settings on the settings page of the loco - or are you adjusting values under the subsequent CV parameters (ie. clicking the cv icon on the settings page and then selecting and adjusting appropriate values for speed, acceleration and braking there under the various cv-parameters)?
Søren
#6 Posted : 18 February 2023 19:19:33(UTC)
I suspect that these locos originally came with the original msd decoders, and the repaired one now has an msd/3 decoder, which will have different drive characteristics. It shouldn't be impossible to speed match them, just take some time.
Offline PFG45
#7 Posted : 18 February 2023 21:08:25(UTC)
PFG45
Yes, it is my impression that the repaired loco has a new decoder - hence any good advice on adjustments in general would be appreciated ? 😀
#8 Posted : 18 February 2023 22:02:54(UTC)
Hi Søren
With a CS2, the edition screen is easy to reach
- select the loco
- press the wrench key
- select the tab motor to edit the needed variables
You obtain a screen like this (sorry in German here.
The frames zones show you where to edit the max speed, acceleration delay and braking delay
Don't forget to load into the loco by pressing the key with a downwards arrow to a locomotive
Offline dickinsonj
#9 Posted : 19 February 2023 01:12:24(UTC)
(sorry in German here...
Strangely a lot of menus are still in German on my CS3 in English language mode.
It is good for my dormant German language skills. ThumpUp
Offline PFG45
#10 Posted : 20 February 2023 19:24:59(UTC)
PFG45
Thank you very much Jean for clarifying this.
Did a quick test and just using the same parameters gave a good initial result. Now I just need to fine tune the parameters a bit more.
With regards to adjusting maximum speed what is the general advice? To max the speed at say 140 or keep it at default (which in this case is 180)?
Søren
#11 Posted : 20 February 2023 22:44:47(UTC)
Hi Søren
Normally (not for multiple traction) I use the maximum speed to limit the speed to a prototypical one.
For an additional loco forming a multiple traction with the first one, I adjust the maximum speed so that it matches the first loco's
regarding the odometer scale, I match the official maximum speed (does not play any role).
When my wife is going better (and I can use my layout again), I will install on my Rocrail the creation, usage and breaking of a multiple tractions. I just tested the theory and testing on a length of rail.
Offline PFG45
#12 Posted : 23 February 2023 22:35:48(UTC)
PFG45
Hi All
Thank you for your kind help so far. I will test the various parameters over the weekend to further fine tune the two locos thanks to your helpful advice.
Jean, look forward to hearing from you when you have had time to complete your tests.
Søren
Offline PFG45
#13 Posted : 05 March 2023 17:04:55(UTC)
PFG45
I have further refined the parameters so I am pretty ok with the results so far.
While testing the acceleration of the locos, the loco behind the first one seems to fall behind a bit (about 10 cm) but then they pretty much keep the same speed.
However, over three minutes at basically constant speed the loco following the first loco eventually reduces the gap with about 5 cm and then subsequently catches up with the first over the following three minutes.
What is the recommended sequence to which loco should be first - the slightly faster loco (so it will be pulling) or the slightly slower?
Søren
Edited by user 06 March 2023 08:52:30(UTC)  | Reason: Typo
#14 Posted : 06 March 2023 04:59:28(UTC)
While testing an acceleration one of the locos (the one behind the first one) seems to fall behind a bit (about 10 cm) but then they keep the same speed.
However, over three minutes at constant speed the loco following the first catches about 5 cm and then subsequently catches up with the first over the following three minutes.
Søren
Soren, I would let the faster one do the pulling, what I have done with mine, I turn the acceleration and braking delay off, so you don't get the push pull situation with both locos.
Offline PFG45
#15 Posted : 06 March 2023 08:54:07(UTC)
PFG45
Thanks John,
I will try that!
Søren
This page was generated in 0.433 seconds.
