#1 Posted : 09 February 2023 18:05:21(UTC)
This was test by of Märklinist with different Märklin locomotives.
You can see that even 4 traction tyres does not help to impress tractive power to pull more wagons!
www.youtube.com/watch?v=ggZexsw0uA4
thanks 4 users liked this useful post by Goofy
#2 Posted : 09 February 2023 18:33:09(UTC)
There is another video test with diesel locomotive by same Märklinist.
Online marklinist5999
#3 Posted : 09 February 2023 19:20:39(UTC)
Both are interesting. Of course the heavier Locs suffer less wheel slip, and the Compact C sine and older motors had better torque. In the second, I was surprised to see the br 260 derail at such slow speed, but it is fairly light. Of course uneven tracks pose more of a problem for longer cars and locs.-consists. Speed also plays a role. Marklin steam Locos. with several drivers usually have articulated sets to negotiate curves better. Keeping tracks as flat and level as possible is best.
Offline Copenhagen
#4 Posted : 09 February 2023 21:00:57(UTC)
Copenhagen
You're talking BS again. The two locos with with the most pulling power were a BR 120 with 320 grams pulling power and a BR 182 with 340 grams and they both have 4 traction tyres. The best loco with 2 tyres was a BR E10 with 310 grams.
Besides if you wanted a scientific test you would have to test each locomotive with both 2 and 4 traction tyres and also take into consideration other construction details (like motor and gearing etc).
thanks 2 users liked this useful post by Copenhagen
Offline mbarreto
#5 Posted : 09 February 2023 21:51:05(UTC)
mbarreto
The configuration of the decoders take also its percentage on the results...
Miguel
Mostly Märklin H0.
Offline poulmh
#6 Posted : 09 February 2023 22:13:07(UTC)
poulmh
I only see some lokomotive with some text
____________
Poul M Hansen
thanks 1 user liked this useful post by poulmh
#7 Posted : 10 February 2023 09:23:40(UTC)
That was total pointless comment!
In fact does video show test result of different locomotives.
What it matter are low point of gravity that impress tractive pull power, whatever 2 or 4 traction tires.
The video are fair test so your comment are total waste.
#8 Posted : 10 February 2023 09:45:31(UTC)
I can't see the value in having tests done on locos you've bought because you like them or you bought them for a specific reason believing they have a good pulling power., such tests are inconclusive as other matters have a bearing on a locos pulling power, clean tracks, new rubber tyres, etc etc., it may give you an approximate result, on the other hand one should find out why these locos have a different pulling power and what are the resons behind it, unless you'll find the reason the tests are for what purpose ?
Offline Copenhagen
#9 Posted : 10 February 2023 11:44:56(UTC)
Copenhagen
The video shows that the two locos with the most pulling power have 4 traction tyres. That's indisputable!!
(Though you often dispute facts). Many of the locos with 4 tyres have relatively low pulling power. But what would their pulling power be if they had only 2? Lower or higher? If it would be lower it's a proof that 4 is better than 2.
#10 Posted : 10 February 2023 12:40:23(UTC)
Can I see that? Not really.
The test shows that four powered axles with four traction tyres are better than two powered axles with four traction tyres. What a surprise.
Four powered axles with two traction tyres sometimes pull about as good as two powered axles with four traction tyres. What a surprise.
Oh, and loco weight matters. What a surprise.
#11 Posted : 10 February 2023 13:46:43(UTC)
I think everyones points have some validity. Depending on the weight of the Loco., many heavier 2 axle powered ones have the best tractive effort with 4 tires, unless one with two tires has each firmly set into just the right curve. Then I don't think it matters how many powerd axles. Are any CoCo Marklin's 6 axle powered, like a br 103, An SJ my series, or an SBB ae 6/6?
#12 Posted : 10 February 2023 13:55:32(UTC)
Thanks for the interesting video
The pulling power as you know depends on multiple factors:
- the wheel tires how new they are, how clean they are (a tire contaminated with oil is good for replacement)
- the weight (vertical force) applied to wheels with tires.
- the rail cleanliness and upper surface (flat, round, oily, etc)
- the rubber tire position on the loco (e.g.: an old BR 01 with tires on the rear axle, will pull much more when forwards compared with reverse)
- the rail type: straight or curved, the more curved, the less pulling power, on many track pieces (DSS, points, crossings) the pulling power reduces sharply due to tire offload.
Offline Copenhagen
#13 Posted : 10 February 2023 14:06:27(UTC)
Copenhagen
When I watched the video I took notes:
Here is the pulling power in grams for locos with 4 tyres:
250, 214, 270, 140, 140, 320, 185, 215, 340, 210, 195.
For the locos with 2 tyres:
65, 120, 310.
(I only watched the video once, so I haven't checked if I've gotten anything wrong).
Offline Toosmall
#14 Posted : 10 February 2023 15:31:36(UTC)
Toosmall
Just need to repeat it all in Z gauge where there are real issues.
Traction tyres on 3rd axle works best as this one gets pushed down on the rails, 2nd and 4th axles lift due to the drive gears. The 3rd axle is more to the centre of the loco to benefit from weight along the loco.
#15 Posted : 10 February 2023 15:32:31(UTC)
I find it strange that the formula 1 teams have so many different types of tyres,
when they could just drive on the rims without tyres.......... LOL Laugh LOL
#16 Posted : 10 February 2023 16:17:37(UTC)
Think of all the money all those fancy sports car owners could save as well. Laugh Laugh Laugh
Tyre companies would go out of business ... Blink Blink
#17 Posted : 10 February 2023 16:21:53(UTC)
They may aanyhow once the human sized drones hit the market! Pick me up, fly me to point B, etc. No more gas or insurance to buy either!
This page was generated in 0.731 seconds.
