Offline einotuominen
#1 Posted : 07 February 2023 13:26:18(UTC)
einotuominen
Hi guys,
this is very Rocrail specific. Brakes squeal perfectly when driving manually, so that is not an issue here.
But in Rocrail automatic mode. There is a feature called BBT (Block Brake Timer) that gradually decelerates loco between a block enter and in sensors. It is a great feature as it will after a few attempts learn how to slow down the loco so that it will look smooth and stop with precision.
But with it goes away the brake squealing.
With BBT the velocity will be set to 0 eventually, but it is not a sharp curve as the loco has been decelerating already for several seconds.
Has any one got a proper solution for this? Installing a speaker inside station building and playing sound files through that is not in my opinion a very nice solution.
I know that JohnjeanB is driving automation with mSD3 locos, have you got any experience? Love
-Eino
Offline PMPeter
#2 Posted : 07 February 2023 16:33:53(UTC)
PMPeter
I use Rocrail and BBT and I have no issue with the brake squeal. In my case it doesn't happen when the loco enters the block and the BBT kicks in, but the squeal starts when it is in the final step of deceleration and hits the In sensor. It works for all of my locos.
#3 Posted : 07 February 2023 16:37:03(UTC)
einotuominen
Have you made any changes to the decoder thresholds?
I don’t get the squeal at the In event when velocity goes to 0.
However squeal happens on non BBT blocks if loco is to stop in the block.
Strange…
-Eino
Offline PMPeter
#4 Posted : 07 February 2023 17:47:22(UTC)
PMPeter
No I made no changes to the decoder. I get the squeal in BBT blocks on the In event and in non BBT blocks if the loco has to stop due to an occupied next block. I am using a CS2.
Offline PeFu
#5 Posted : 07 February 2023 18:24:50(UTC)
PeFu
I have experienced similar features on some decoders. You could try changing the ”Threshold for brake squealing” of the decoder (CV64), using a value of 1-255:
The higher the value the sooner the squealing begins, the lower the value the later the squealing begins. If
the value is too low, no squealing is activated.
(From the mSD3 manual.)
Offline Martti Mäntylä
#6 Posted : 07 February 2023 18:29:08(UTC)
Martti Mäntylä
Set decoder deceleration to take place faster and/or from higher V_min and the squealing should emerge at some point.
This comes with the loss of some control, as Rocrail cannot stop the loco precisely at the sensor any longer.
Edit: PeFu beat me in replying. His suggestion may help too, but I have no experience on this approach.
- Martti M.
#7 Posted : 07 February 2023 18:51:54(UTC)
einotuominen
All right! Great suggestions. I'll try out both of them together and separately.
Thanks!
-Eino
#8 Posted : 07 February 2023 22:57:43(UTC)
Hi Eino
Originally Posted by: einotuominen Go to Quoted Post
Hi guys,
-Eino
The only thing Rocrail does differently compared to manual control is multiple digital orders to change the speed so the Squealing Sound (SS) may be affected
Speed generally used by Rocrail
- V_max: normally not used
- V_ cruise: speed used when between blocks
- V_med: speed when approching a closed (red) signal
- V_min: speed used in detailed blocks, on staging blocks, on turn table
Note: the above speeds are defined specifically for each loco and block speeds or route speeds can be different in percentage of the max speed the loco in the block or route.
Things not done by Rocrail (done by the loco decoder)
- inertia (called acceleration delay , braking delay)
- braking squeals parameters: minimum speed to reach before the sound started, the speed level when the squealing sound is triggered, and many others (See below)
- braking squealing inhibition
- maximum speed (as defined in the CS3 and CS2) and may be used to reduce the maximum speed to a realistic value. (so ROCRAIL's Max speed difinition is CASCADED with the CS3 Maximum speed (e.g.: CS3 Max speed is 90% and RR Max speed is 80% then RR resulting max speed will be that of 0.80x .090) of the locos absolute max speed.
Sorry for these long preliminary notes.
So, to be clear, Rocrail does not do ANYTHING to inhibit squealing BUT, the succession of speed change order may prevent the squealing sound to be heard.
So the parameters on Märklin recent decoders (mSD3 and mSD2) I know (there may be more) are
- CV 164 "Bandbreite Bremsschwelle (bandwidth speed threshold. It )is the duration (time) of the brake squeaking. The higher the value, the earlier this noise starts when stopping (value in 0.1 seconds) Recommended value=5
- CV 163 "Korrecture Auslauf".(Correction factor progress) allows to correct the start of SS when too early or too late. Recommended value is 2
- CV 64 "Bremsenquietschen Schwelle" (0 - 255). This is a SS threashold.The squeaking begins, the larger the value, the earlier, the smaller the value, the later. If the value is too small, no squeaking is triggered. Important note: this treshold is to decide IF the SS will be triggered and not AT WHAT SPEED. See it as a condition.
Sorry the subject is not easy to digest but:
- consider adjusting the SS parameters on the MFX decoder
- strangely it will work better when having strong speed variations
#9 Posted : 11 February 2023 10:54:40(UTC)
einotuominen
Thank you guys, I’ll start experimenting and get back to this topic if and when I find proper settings.
-Eino
thanks 1 user liked this useful post by einotuominen
This page was generated in 0.446 seconds.
