Offline mjborelli
#1 Posted : 06 February 2023 01:51:24(UTC)
mjborelli
I am trying to replicate a previous AnyRail Windows track layout using my new Railroader Pro software program. During the construction of a train loop I used to be able to in AnyRail grab the loop and move the entire loop or rotate the entire loop. I tried doing that with Railroader Pro but so far just individual track pieces move and not the entire loop. Is there a tool I should be using within the app to do this?
Thanks for your help/advice.
Offline nhumps
#2 Posted : 06 February 2023 03:30:22(UTC)
nhumps
A couple of options: Triple click on a piece will select everything that is joined together. Or use the selector tool to drag a selection around the pieces to then select the group of items you want to then rotate.
You can also group items once selected and then easily select and rotate the group after too.
thanks 1 user liked this useful post by nhumps
This page was generated in 0.321 seconds.
