#1 Posted : 06 December 2022 12:31:01(UTC)
If I purchase two Marklin locomotives the same will one register with a different address or will both respond to the same address when controlling. Was thinking of buying a loco same as one I already have. Not sure if you can change an address but then again CVs are a bit beyond me (its an age thing lol)
#2 Posted : 06 December 2022 12:33:00(UTC)
They will get different addresses. The mfx address cannot be set manually.
Decoders are identified by their serial number, not by the name.
#3 Posted : 06 December 2022 13:03:15(UTC)
Suppose you wanted to use them with the same address on a non MFX controller like a 6021, then the factory set address would be the same per the user manual? This might be beneficial in tandem multi unit operation, when other trains are running. Otherwise, with a CS2, or CS3, the MFX protocol would need be disabled to do it before auto recognition?
#4 Posted : 06 December 2022 14:13:49(UTC)
Thanks for that. Interesting that all locos are recognised by their serial number of the decoder fitted and not the loco so will go ahead and buy another of the same.
loco mfx registration problem (Digital)
by Thewolf 01/01/2023 14:11:14(UTC)
This page was generated in 1.926 seconds.
