Offline bph
#1 Posted : 12 October 2022 20:29:47(UTC)
After recently having a good experience with the ESU 50344. I was searching for a different speaker and came across the Roads and rail and their EM1 Ultra Bass Speaker. At first, I assumed that it was the ESU speaker but then I noticed that they had different numbers written on them and that Roads and rail recommend a second speaker to be installed together with the EM1, and ESU does not have that recommendation. (but I might try it.)
Esu 50344: marked NAV47
24mm x 55mm x 8.6mm, 4 Ohm. Watt ? (have seen shop listings with 0,5W and others with 2W.)
RR EM1: marked NAX48
24.5mm X 55mm X 9mm Deep 0.5 Watt, 4 Ohm.
So is it the same speaker? and who actually makes them. ?
Offline bph
#2 Posted : 13 October 2022 17:37:40(UTC)
By chance, it seems that I found the maker, Tang Band Speaker:
http://www.tb-speaker.com/products/t0-2008s#tab-105
This page was generated in 0.221 seconds.
