Offline rhfil
#1 Posted : 05 October 2022 21:05:41(UTC)
rhfil
I have a ho locomotive with two sets of wheels that are narrower than they should be which causes a short at some switches. Is there a tool designed to adjust the spacing of the wheels? Preferably on the locomotive. These are truck wheels and tender wheels, not drive wheels. Also is there a decent gauge for checking them?
Offline bph
#2 Posted : 05 October 2022 21:37:13(UTC)
Tak a look at fohrmann.com they probably have whats needed.
https://www.fohrmann.com/en/railway-modeling-tools/wheels-axles
Offline Copenhagen
#3 Posted : 05 October 2022 21:42:47(UTC)
Copenhagen
There is a German company that has these kinds of tools in their railway modeling tools section:
I would imagine that US model railway shops/companies will have similar tools?
Fohrmann has a rail gauge tool that measures wheel spacing, 13.8mm for Maerklin and 14.3 mm for DC. But you could also use a calliper to get precise measurements. Take note that 13.8 is on the small side, 14mm should be better. At least compare the wheel spacing on some of the other axles.
On a side note I believe that I've been able to increase the wheel spacing on a locomotive with hand tools without removing the wheel set... with the utmost care not to damage anything of course.
I have some of the Fohrmann tools and use them a lot on non Maerklin cars and waggons.
Posted at the same time as the answer above :-)
Offline STE-BM
#4 Posted : 05 October 2022 21:49:07(UTC)
STE-BM
I wrote this guide a while back as I’ve seen many people needed a simple way to convert DC wheels to AC.
It requires to change the wheel flanges spacing like in your case.
Have a read here and you probably can find the tool on Amazon or eBay:
Motor Gear Puller https://amzn.eu/d/6J8kzaf
thanks 1 user liked this useful post by STE-BM
This page was generated in 0.241 seconds.
