#1 Posted : 14 September 2022 22:34:49(UTC)
Bryan
Dear All
Has anyone created their own sound files and uploaded them to a mSD/3 sound decoder.
I have the sound file in the folder called David Folder and file named Test1.wav
My sound file plays when I hit the play button as in the screen dump.
How do I basically get from here to actually getting the sound file on the decoder through the mDecoderTool.
Any suggestions, thank you in advance.
David
thanks 1 user liked this useful post by Bryan
Offline bph
#2 Posted : 15 September 2022 20:41:48(UTC)
I create simple audio files quite often.
it seems that you are nearly there. when you have a single file, add it to the stat section and it will work fine. just click on the green ok symbol. and you have created a sound file (not a folder).
After that, it's just to click add sound and drag the new file over from the "eigeneBibliothek"
And then map it to a function, and for simple sound files like this, "momentary Function" mode, is recommended in most cases.
In the window, you have open you can click on different folders, and get instructions for different types of sound files.
Sometimes I also use an audio tool to shorten, clean, and/or amplify sound clips etc. (non Märklin files) I use the free audacity, but there are also others.
Offline costing
#3 Posted : 15 September 2022 22:38:31(UTC)
costing
Hi Bryan,
Please see this post where I've documented my experience with the same: https://www.marklin-user...rum/posts/t41091-Custom-
.costin
thanks 1 user liked this useful post by costing
#4 Posted : 17 September 2022 03:13:51(UTC)
Bryan
Thanks for all the help.
I had 3 sound files to download to the mSD/3, they were Flemish station announcements.
The main point to remember in the process is it has to be two step.
Firstly create a 'start.wav' file from your own souind wave file in the mDecoderTool.
Then save the project, exit and take your own file out of your directory that has both files.
The start.wav file needs to be on its own, to transfer into a P key function in mDecoderTool.
Otherwise you get file format error messages.
Also with each extra sound file, rename the source directory for each file load, otherwise they overwrite.
Other than that it is pretty straightforward.
best regards
David
This page was generated in 0.267 seconds.
