Offline Rarpos
#1 Posted : 12 June 2022 05:46:17(UTC)
Rarpos
I am enquiring if there are relatively simple booklets in reference to wiring on Marklin layouts. I am a long time collector, but have not had any information on how to electrify points and crossovers, and how to isolate sidings, etc.
Any information would be appreciated.
#2 Posted : 12 June 2022 14:28:40(UTC)
Check the 0340 Signal manual in this post.
The Eckart Engineering Wiring Booklet further down the same post may also be useful.
Offline Rarpos
#3 Posted : 13 June 2022 01:57:23(UTC)
Rarpos
Many thanks.
#4 Posted : 13 June 2022 13:12:04(UTC)
You probably should check this thread which has the things you are requesting.
https://www.marklin-user...ns---requested-documents
In addition to the Signal manual Alan mentions, the thread has links to
Eckert Engineering Marklin Wiring Booklet
Connecting Electric Railways Book
Offline Keim
#5 Posted : 17 June 2022 00:15:13(UTC)
Keim
I found lots of wiring diagrams available on ajckids.com. I inherited a marklin analog and had to learn from scratch.
Offline Keim
#6 Posted : 22 June 2022 21:33:17(UTC)
Keim
Re: isolating sidings. Black electrical tape on the Power contact at both ends and a power feed wire for the isolated section. I use push button on off switches to feed the sidings.
This page was generated in 0.426 seconds.
