Offline HO Collector
#1 Posted : 09 May 2022 23:35:38(UTC)
HO Collector
Can someone please confirm if the current ESU models will /function with Mobile Station II?
Specifically looking at model # 31337 and 31014.
Thank you
#2 Posted : 09 May 2022 23:47:12(UTC)
The old firmware of the Mobile Station 2 is buggier than Maine in June and must be updated for use with modern ESU and Märklin decoders.
The locos will work if the firmware of the MS2 is sufficiently new.
#3 Posted : 10 May 2022 12:39:51(UTC)
HO Collector
Thank you.
What I got is the box that contains the unit and an oval, I guess that it is about 3-4 years old.
Will need to find a way to update the s/w, I understand that there is a need for Central Station to do it.
Thank again.
#4 Posted : 10 May 2022 12:52:14(UTC)
Odds are good that the firmware is fit for modern decoders.
Update can be done from MS2 to MS2. CS2 and CS3 are the other options.
#5 Posted : 10 May 2022 22:19:39(UTC)
HO Collector
Thanks. Update is always a good way forward.
This page was generated in 0.420 seconds.
