Offline bulenty
#1 Posted : 06 May 2022 09:26:32(UTC)
bulenty
Turkey
To remove body seen one srew front ,one screw back but two screw back.Anyway whille I remove body I saw thin,little cable back feder and it was braeked.I coulld not find ,it's solder point.Now the loco could not running.
Is there any guy to hellp?
I am sory for my bad english
Offline ocram63_uk
#2 Posted : 06 May 2022 11:57:57(UTC)
ocram63_uk
is the body of the loco completely off now? Can you attach a picture?
Can you switch on/off the lights / sound or they do not work either?
The pick up shoe is under the tender.
There should be cables connecting the tender and the loco, are these all intact?
Black for Marklin is a ground contact. Usually
Unfortunately the exploded view of the loco deos not show where cables are attached
37015.pdf (1,102kb) downloaded 35 time(s).
Offline bulenty
#3 Posted : 08 May 2022 08:30:49(UTC)
bulenty
Turkey
I remove cae completlly.ike short circuit fonctions blinking.For exampe whenI press light key ,smoke fonktion blinkiing.You are right,the cable ground contack but Marklin trains have a lot of ground
any way I hope I will send it to service
This page was generated in 0.460 seconds.
