Offline thulasa
#1 Posted : 24 March 2022 12:36:51(UTC)
thulasa
Hi there!
I accidentally deleted a 76496 signal with automatic CS3 address.
I tried to reconnect this signal automatically... but the CS3 doesn't recognise it.
I've also try to set the address manually... but the MFX doesn't appear.
Any tips?
Andrea
#2 Posted : 24 March 2022 13:14:15(UTC)
Hi! I have that signal also. Try using "find lost mfx items". Use the same steps you did the first time if it isn't found. Select the same settings. This is a 2 address signal. The CS3 chooses the second address in succession to the first. Did you maybe only delete one address?
You should be able to remove both adresses, then you should be able to reinstall it automatically. I'd shut down the CS3 after you remove it, then add it after restart.
Read the instructions again. I am not certain, but I think I recall that the automatic address selected by the CS3 can not be altered. Also watch the Trainguy's video on CS and mfx signals on youtube. It may help. He is knowledgable and Germna, but speaks clear English.
Hope this helps!
Offline thulasa
#3 Posted : 24 March 2022 14:01:50(UTC)
thulasa
Thanks a lot for your help!
In the meanwhile I've just solved with a restore backup!
Andrea
thanks 1 user liked this useful post by thulasa
#4 Posted : 24 March 2022 20:58:47(UTC)
Excellent!
This page was generated in 0.213 seconds.
