#1 Posted : 10 March 2022 15:02:50(UTC)
Just curious. There are still a few in shops. Did you set the adress first on the control unit, then push the code button on the decoders to lock it on?
Offline franciscohg
#2 Posted : 10 March 2022 23:54:21(UTC)
franciscohg
Chile
Mmmm, did not found a manual online
In others DCC decos with programming Buttons the procedure is to push it to enter programming Mode and then send a command with the control unit in the desired first adress. Perhaps it works similar. If they are new the surely comes with the proper manual.
Offline franciscohg
#3 Posted : 11 March 2022 00:08:29(UTC)
franciscohg
Chile
I have found a short video of programming an Arnold decoder, wich is supposed to be the same.
Short video with no explanations, but seems to show a similar procedure
#4 Posted : 11 March 2022 00:33:10(UTC)
Thank you Francisco!
This page was generated in 0.248 seconds.
