Offline obb1016
#1 Posted : 28 February 2022 16:33:43(UTC)
obb1016
I purchased several Piko light strips (https://www.piko-shop.de/is.php?id=22047) for Piko SBB coaches, but I have some concerns about the decoders and their hookups. The Piko directions say that I need to use Piko decoder 56126 on their 56286 light strip. Apparently that decoder is the old Uhlenbrock function decoder 76 900, which hasn't been made for a while. The Piko ones are also out of stock at Piko (Piko has even deleted the part number).
I can read the Uhlenbrock/Piko schematic only partly, so I will explain. Here is the address: https://www.uhlenbrock.d...andbook/en/Bes76900e.pdf
On the decoder diagram you will see 4 function highlights: A1, A2, A3, and A4, with 2 more connections made to WR (to AC slider) and WL (to ground). But the PDF also references a green wire that attaches to A3, and a blue wire that attaches to F+. Can anyone understand what these terminals are (especially F+, which is not referenced in the Piko diagram)?
Moreover, is there an ESU equivalent function decoder that I can buy instead of Piko 56126? And if so, could anyone advise on the terminal connections on A1, A2, A3, and F+...A4 and WR and WL?
Best,
George
Offline mario54i
#2 Posted : 28 February 2022 20:32:51(UTC)
mario54i
As usual, manufacturers suggest using their accessories, that are usually more expensive than similar parts of other brands.
A normal light strip (without decoder) is just a pcb with some LEDs and resistors and maybe few other parts, they just require some electricity to light up.
All function decoders can drive the light strips, just connect the F+ (blue wire) to positive input of the strip (in case the strip has a polarity) and A1-A4 at your choice to negative input.
Different matter for Piko SBB pilot coach, it needs a strange decoder with strange non standard connections, only Piko makes it.
This page was generated in 0.210 seconds.
