Offline frickwg
#1 Posted : 21 January 2022 01:21:26(UTC)
frickwg
There are lots of HO scale rail tunnel portals but where might I find an Automotive tunnel Portal?
Rail tunnels are in a different height/wide ratio, for obvious reasons.
thanks 1 user liked this useful post by frickwg
#2 Posted : 21 January 2022 09:32:37(UTC)
Depending on the era you're modeling and the width of roadway, there may be some rail portals that can work. An example is the European ICE portals
Which look just like the expressway ones through the Alps, etc.
I have used a Vollmer single track steam era portal on a 2 lane road mountain tunnel.
Additionally, you could make them either by 3D printer, or use various diameters of pvc white drain pipe and couplings for modern ones.
A square brick portal could even be made of a block of wood or plywood.
Ones that comes to mind are the Fort Pitt and Squirrel HILL tunnels in Pittsburgh. The Liberty tunnel has a square shape with round portals.
The bricks can be painted on or use glue on paper photo sheets, or cast rubber or plastic ones from Chooch enterprises, Busch, Faller, etc. They make different colors and sizes of retaining walls, etc.
Online DaleSchultz
#3 Posted : 21 January 2022 15:53:07(UTC)
I was able to convert a rail portal to my satisfaction. I think it was by Noch, it is a foam material and I cut it shorter with a work knife.
#4 Posted : 21 January 2022 16:28:58(UTC)
Noch are wonderful! You have to cut pvc pipe on a table saw to height in half or by a quarter or a third.
#5 Posted : 21 January 2022 17:27:41(UTC)
#6 Posted : 21 January 2022 18:09:32(UTC)
Those Viessmann led ones are cool! About $55 U.S. though. Led strips can be bought very cheaply, as well as resistors.
Offline frickwg
#7 Posted : 21 January 2022 18:42:10(UTC)
frickwg
The Faller is fine, but I need something flat to the wall.....
#8 Posted : 21 January 2022 19:21:02(UTC)
You can cut it flat, or cut pvc flat also, and the Noch tunnels cut with a knife.
Online DaleSchultz
#9 Posted : 21 January 2022 19:57:12(UTC)
the inside of the tunnel can be made from Styrofoam, and either painted or lined with paper printed with brick/concrete/etc.
This page was generated in 0.375 seconds.
