Offline Uthred
#1 Posted : 08 December 2021 17:11:19(UTC)
Uthred
I just bought the new CS3 plus and try to run 3 older digital locos on my layout. My Mfx locos registered with no problem and run fine with all bells and whistles
The issue is with those 3 I bought 2nd hand with no instruction manual
- SBB Krocodile 14310. CS3 is recognizing the loco with pic but I’m not sure what the digital setting is to make it run
- SBB 11376 not recognized by CS3
- DB E 40 072 not recognized by CS3
I tried various settings to no avail
Btw. I run them on my old layout without a problem
Can someone guide me in the right direction
Thank you
Rudi
#2 Posted : 08 December 2021 17:26:50(UTC)
Non-mfx Märklin locos can be registered from the database using the ref. numbers. You may have to adjust the address if it has been changed.
The E 40 072 has DIP switches and you can read the current address from those DIP switches.
Offline Uthred
#3 Posted : 09 December 2021 00:21:35(UTC)
Uthred
That’s the issue, the DIP switches are all in the off position
How do I find the correct numbers?
#4 Posted : 09 December 2021 00:39:45(UTC)
These tables show you the settings:
Dip switch codes 2.pdf (811kb) downloaded 106 time(s).
This page was generated in 0.379 seconds.
