Offline Toosmall
#1 Posted : 29 November 2021 01:26:15(UTC)
Toosmall
I have used a lot of super glue over the years. Zap-a-gap is brilliant. Zip Kicker to accelerate hardening, the spray bottle is probably enough for most people and is a handy size, but do NOT use the spray nozzle. Take it off and use a piece of wire, a large unfolded paper clip will do to apply 1 drop. Very important, make a stand so you do not knock the bottle over, I eventually learnt!
Z Ends to apply precisely, are worth it, just get them. The old ends were a nozzle and fine tube, cut the tube at an acute angle and feed the tube in the back of the nozzle. New Z Ends are all in one. Both are good.
Debonder is good if you get super glue on your fingers, but be extremely careful with painted surfaces.
Offline Legless
#2 Posted : 29 November 2021 04:11:47(UTC)
Legless
Debonder is just acetone.
Legless
Offline Toosmall
#3 Posted : 29 November 2021 06:09:20(UTC)
Toosmall
The debonder is very oily so probably a bit better on the skin. I still give a good wash after. Only needed it a very few times, due to having to hold a part in an impossible position.
This page was generated in 0.365 seconds.
