Offline jmallen622
#1 Posted : 20 November 2021 16:46:49(UTC)
jmallen622
Purchased a 37531 Christmas engine on eBay. Problem is it runs via my MS2 unit (reverses and forward) but only the light function shows. I am able to turn the light off and on but the bulb must be burned out.
Is it possible the decoder is no longer fully functional and needs replaced?
Thank you in advance
thanks 1 user liked this useful post by jmallen622
#2 Posted : 20 November 2021 17:21:25(UTC)
Hi, always check the simplest issue first, that being the bulbs. This model only has a light function, and possibly a second to turn off the acceleration and braking delay. Do the red tailights illuminate, at either end, and or change direction with the motor direction? If so, it's the bulb. If not, it could be the decoder, or a disconnected or pinched wire with a broken inside. Unfortunately, when a wire gets pinched on a metal loco frame by the body, it can render that wire's conected point/function on the decoder dead. I have one it happened to.
The L.E.D. long distance headlight still works, but not the single headlight at that end. The other end is fine.
Your's doesn't have led's.
This page was generated in 0.197 seconds.
