Offline jump
#1 Posted : 13 November 2021 00:18:11(UTC)
jump
The TT-DEC decoder can be powered from 16v to 18v.
Is an 18v power supply suitable for connecting the Marklin 7286 bridge or should I use a 16v?
Thanks for your help....
Marklin H0: CS2, iTrain
Marklin Z
LGB
#2 Posted : 13 November 2021 00:34:45(UTC)
are you asking about powering the track on the TT bridge?
If so, it depends on what you use to control your locos.
The bridge track is... track, so you have to supply whatever you normally feed to your rails.
If you are running digitally you have to provide your normal digital track signal. If analog, you pass in your varied 16V analog power.
If you feed power from that Conrad transformer any loco on the turntable will go at full speed.
If you are asking about powering the TT-DEC decoder, you answered your own question, it take 16 to 18V and the Conrad transformer supplies 18V.
In addition to power, I presume any decoder will also need a digital power input.
Offline jump
#3 Posted : 13 November 2021 07:09:56(UTC)
jump
Digital
Yes but my question is: 18v are for the decoder AND the motor ?
The motor is normally powered at 16v.
Yestthe digital power input comes from the Central Station.
Marklin Z
LGB
#4 Posted : 13 November 2021 13:21:48(UTC)
Again, you have answered your own question. The TT-DEC supplies the motor, not the power supply, so whatever power supply is allowed for the TT-DEC is suitable for the TT-DEC to drive the motor.
Offline jump
#5 Posted : 13 November 2021 13:46:11(UTC)
jump
Ok, the TT-DEC is powered with 18v and provide 16v to the motor.
I prefer not to burn the engine.
So this power supply is appropriate (a little too powerful but I think to use it for other accessories too).
Marklin Z
LGB
This page was generated in 0.498 seconds.
