Offline GaryTrooper
#1 Posted : 17 October 2021 06:15:57(UTC)
GaryTrooper
What purpose does wrapping wire around the axle have? I just recieved this wagon and it had wire on the axle of the wheels. Never saw this before.
G - LGB
HO - Marklin
N - Mix of manufacturers mostly Kato
Offline Chris6382chris
#2 Posted : 17 October 2021 06:52:23(UTC)
Chris6382chris
I’m guessing the wheels are isolated. A dc set. And the wire is connecting them and basically making them able to conduct current, making them an ac set able to trigger contact tracks. Just my guess.
thanks 2 users liked this useful post by Chris6382chris
Offline Ranjit
#3 Posted : 17 October 2021 07:01:49(UTC)
Ranjit
Weird !
Ranjit
#Get Vaccinated
thanks 1 user liked this useful post by Ranjit
Offline kiwiracer
#4 Posted : 17 October 2021 07:47:13(UTC)
kiwiracer
Would this be to add some weight to the wagon.
Cheers Brett
Don't dodge difficulties, meet and defeat them. (Anon)
Anyone can eat an elephant, one bite at a time (Anon)
thanks 3 users liked this useful post by kiwiracer
#5 Posted : 17 October 2021 08:30:40(UTC)
Looks like someone lost their Spaghetti, I think there are better methods to add weight to a carriage.
Online Purellum
#6 Posted : 17 October 2021 09:20:32(UTC)
Extra weight BigGrin
It's the best way to add weight, since it doesn't add the weight to the wheel bearings Cool
PIKO makes spare axles for G-scale wagons with extra weight added Cool
https://shourtline.swl4....30mm_Metal_Wheelset.html
Offline analogmike
#7 Posted : 17 October 2021 13:03:47(UTC)
analogmike
I have seen this in an old magazine from 1965. Supper idea.
thanks 12 users liked this useful post by analogmike
#8 Posted : 17 October 2021 13:48:39(UTC)
The other thing such 'weighting' would do is to add drag to the wheels so they not so free rolling. maybe the original owner had problems with his train rolling away after uncoupling on a slight slope.
But, yeah, weird ... Confused Confused Confused
Offline GaryTrooper
#9 Posted : 18 October 2021 20:52:06(UTC)
GaryTrooper
Is this what my wife means when tells me not to get wrapped around the axle? LOL.
Thanks for all discussion points everyone. Very helpful and informative.
Gary
G - LGB
HO - Marklin
thanks 2 users liked this useful post by GaryTrooper
Offline mvd71
#10 Posted : 19 October 2021 21:46:39(UTC)
I don’t think so Alan. If the weight is added in the wagon itself it would result in increased friction in the bearings and therefore increased rolling resistance, but when added around the axle it it increases the mass without loading the bearings. When the wagon moves the wheels roll over the rails not slide, so any change as a result of weight on the axle would be negligible.
#11 Posted : 20 October 2021 00:13:24(UTC)
But the solder would around the axle would create some drag on the axle. On your photo it looks like one end of the solder is poked into a hole in the chassis, so it won't rotate with the axle. I may be wrong, but that is what it looked like to me.
Offline GaryTrooper
#12 Posted : 20 October 2021 00:42:11(UTC)
GaryTrooper
Maybe add a little resistance. More like adding axle mass. Harder to get rotating and harder to stop once it is rotating.
G - LGB
HO - Marklin
Offline mvd71
#13 Posted : 20 October 2021 06:03:30(UTC)
More likely that’s an illusion in the photo.
Offline Copenhagen
#14 Posted : 20 October 2021 17:39:59(UTC)
Copenhagen
Maybe GaryTrooper can report back if the wire is rotating with the wheels or if it's stuck?
I have sometimes struggled with adding weight to cars so new tricks and tips are always welcome.
(Even though I've found that adjusting wheel spacing is often more important than adjusting weight).
thanks 2 users liked this useful post by Copenhagen
Offline GaryTrooper
#15 Posted : 20 October 2021 20:25:11(UTC)
GaryTrooper
The wire does rotate with the axle.
G - LGB
HO - Marklin
thanks 1 user liked this useful post by GaryTrooper
Offline 1borna
#16 Posted : 20 October 2021 20:55:35(UTC)
1borna
Croatia
I did that 50 years ago and on wagons with plastic wheels. It is desirable if you need to add weight to a light wagon that it is as low as possible and another plus is that by turning the heavier axles you get the effect of a flywheel!
thanks 2 users liked this useful post by 1borna
This page was generated in 0.877 seconds.
