Offline MartinS
#1 Posted : 26 September 2021 16:42:43(UTC)
MartinS
I have a Märklin 7686 Turntable in my layout. I'm using LDT TT-DEC module and TrainController for control, and its working fine. But I am not sure how to utilize the "position reached" indication.
I have successfully defined a sensor in TC that indicates the "position reached" status provided by the TT-DEC. But how do I use the sensor to prevent a loco (under automatic control) to start driving onto the turntable until the turntable has reached the correct position?
Do I use the sensor in the turntable block, or in the connecting blocks? Is the sensor used as some kind of condition on the block itself, or on the signal at the end of the block?
Martin
Offline MartinS
#2 Posted : 29 September 2021 12:01:57(UTC)
MartinS
Answer to self: just set the "Position Control" in the turntable Connection tab to point to the indicator previously created.. then it works perfectly! Look a bit closer at the available settings next time :-)
thanks 2 users liked this useful post by MartinS
This page was generated in 0.188 seconds.
