Offline BenP
#1 Posted : 21 September 2021 18:19:06(UTC)
BenP
You have been a member since:: 04/02/2021(UTC)
I converted from analog to digital with decoders in trains and for track (incl S88). Next, I want to get train shuttle operation (back and forth on one track), just like analog Marklin 6600. I do not want to use a PC for operation, so found IR detectors options. I use Uhlenbrock Intellibox I, which seemingly has connectivity for systems Marco and Lissy. Not sure what their difference is.
I want to run a small tram (equipped with basic decoder):
  • Stop at end of track
    Wait for, say, 30 seconds
    Reverse direction and move
    Stop at other end of track
    Wait for 30 sec
What do users recommend?
#2 Posted : 21 September 2021 19:22:11(UTC)
A PC.
Some processor needs to do the 'thinking' of taking a sensor input, slowing the loco down, stopping, changing direction, waiting 30s and starting the loco up again, ignoring the sensor as the train moves away from it and waiting for the sensors at the other end.
If you don't want to use PC you need something else to do the data processing. I don't think the Intellibox I does that by itself.
#3 Posted : 21 September 2021 20:17:36(UTC)
Circutron had a reversing relay with limit stops for analog operation.
#4 Posted : 21 September 2021 22:01:05(UTC)
    Wait for 30 sec
For a single tram running on a DC track this could be done quite simply by having a delay module that reverses the voltage to the track periodically. A diode in one rail at each end will isolate the voltage in the direction of travel towards the end, but then allows the current to flow when the DC voltage reverses to allow the tram to go back.
Otherwise as Dale said, to do that sort of thing will require some form of computing device.
However this can be as cheap as a Raspberry Pi. An RPi model 3 or model 4 will run the JMRI program (which is free) just fine, and it will talk to an Intellibox through Loconet just fine. There is also a high level language on JMRI to simplify programming up what you want to do (look at the YAAT pages).
On top of this you will need some way to detect train position, using contact tracks or other sensing options (Infrared detectors, reed switches, etc). The choice here is almost as broad as you want to make it. If you are happy assembling electronic projects then there are kits for s88 sensor units (available from Viessmann or LDT, among others) or you can buy completed units. The Intellibox will connect the s88 units to whatever computing device you use.
Alternatively you can use a hobbyist computing element like an Arduino to process the detectors to get them to your computing device.
If you need only a handful of sensors then JMRI can use the GPIO pins on a RPi as inputs. This would work well for a single line shuttle with four or five stopping points including the end points. This could allow a couple of trains to shuttle up and back with a passing loop at the half way point.
#5 Posted : 21 September 2021 23:10:15(UTC)
I have envisaged (and coded) this for my RemoteSign devices, even mapping the sensors on multiple devices into the s88 address space in my train software, BUT certainly the ESP8266 modules I am using expect the GPIO pins to be grounded to the GND pin of the ESP. I built some optoisolated circuits to ensure that DCC or 16VAC or DC current from the layout would not fry the ESP and it that worked too. Do you know if the RPi also needs an isolated solution? I don't think I can share the ground of the ESP with layout ground even if the negative of its DC input is the same as layout ground. It may be worth frying one to find out.
#6 Posted : 21 September 2021 23:47:58(UTC)
I would certainly use an isolated solution, otherwise the engineering involved in guaranteeing that the grounds are common can get mind bending. In terms of the OPs requirements i was envisaging using the C track 2499x pieces with the microswitches, and lifting the common wire from the track ground and taking it to the RPi common.
Offline Johnvr
#7 Posted : 22 September 2021 10:57:53(UTC)
Johnvr
Which train controller are you using ?
Marklin Central Station / Mobile Station ?
Other brand ?
If you are using the Marklin Central Station or the ESU Ecos, and your s88 is connected to your Central Station/ESU ,
then all you need is to have a Marklin circuit track on either end of the shuttle line in order to feed back the endpoints,
and then you programme the shuttle and timing into the central station.
Easy-peasy !
RegardsBigGrin
#8 Posted : 22 September 2021 15:13:36(UTC)
he is using Intellibox I
Offline Harvey
#9 Posted : 23 September 2021 23:25:19(UTC)
Harvey
Not sure if this helps you as I use a CS2.
I run 1 shuttle on K track with sensors ( circuit tracks). The train sounds the whistle, leaves (station 1) as it approaches the other station (station 2), horn sounds, stops, reverses, sounds horn and leaves. As it approaches the home station, sounds horn. Stops, reverses direction and repeats. All done with CS2, sensors. Took a while to get running but basically flawless operation. I also use this shuttle to launch a rail bus on a separate circular route when the shuttle leave station 2. The rail bus has a stop half way around the loop. Sounds it's horn at each stop.
The only issue (seldom) is if I stop the operation and switch other locs on/off (on other tracks), the shuttle may get confused and go in the wrong direction at first. Just need to stop, change direction and launch the shuttle route on the the CS2.
Harvey
Offline BenP
#10 Posted : 09 December 2021 15:55:18(UTC)
BenP
Thanks for the suggestions and clarifications. I took the easy path by buying a (pricey) CS3+ that recognizes circuit and contact tracks through a s88link. Then, adding CS3 instructions on isolated shuttle track (common ground) to stop, wait, reverse, etc. The 3016/4018 shuttle works great.
#11 Posted : 09 December 2021 18:49:06(UTC)
The big CS new edition book has how to program an automatic shuttle event using two contact tracks, or reed switches, and an S88. Also refer to the Youtube Marklin webinar on basic and advanced events.
Offline Michael4
#12 Posted : 09 December 2021 23:27:03(UTC)
Michael4
I was going to chime in and say don't forget 6600 but then realised that you mentioned it in your original post. It is excellent for this kind of thing (analogue of course) and can also slow the train/tram prior to reversing.
Alan, by the way, any news of the one I fried?
#13 Posted : 10 December 2021 14:27:06(UTC)
Sorry, have been tied up with various things. Am getting back to it shortly.
Alan
Offline Michael4
#14 Posted : 11 December 2021 23:21:11(UTC)
Michael4
Alan, many thanks, I've got that 6600 itch again!
Offline BenP
#15 Posted : 11 December 2021 23:59:08(UTC)
BenP
I tried to get one, but they sell for $80-100, and rarely in US. Went all digital instead. Yes, much more expensive in the end.
Offline BenP
#16 Posted : 19 December 2021 17:22:38(UTC)
BenP
Got the isolated shuttle track done, with 2 end stops and two along way stops, using 4 contact rails. Now thinking about sharing track segments.
In old analog days my signal would cut track power for one train, allowing other train to proceed, and vice versa (two sensing tracks). That seems crude solution with CS3+ control. What are some ways to achieve this (and avoid crashes) with digital?
Thoughts?
Offline Tie
#17 Posted : 21 December 2021 17:19:14(UTC)
Tie
With CS3 and s88 connected to contact tracks you can program almost anything you want in events. I think for me it is my own logic that sets limitations, not the cs3. An event may be compared to a list of commands an you can set each command to execute immediately, agter a time delay or pending a contact is triggered. You can find a some info on the internet bif you are interested, send me your email adress an I can send you some explanation and pictures of may way of using events.
Thor Inge
thanks 1 user liked this useful post by Tie
Guest (11)
This page was generated in 0.430 seconds.
