Offline Rocca
#1 Posted : 21 August 2021 09:20:44(UTC)
Rocca
Hi, dear Märklin friends, Iìm just building (having yet my digital layout) a new one all vintage. Have you, please, any suggestion for cleaning them from the dust? Sometimes the locos cannot run properly. I've used petrol for cleaning them, but it worked only few days. Could be sand paper better? What is your opinion, please?
Stefano Rocca
#2 Posted : 23 August 2021 01:23:39(UTC)
Hi Stefano,
I dont understand why the petrol does not do the job.
If the trains run successfully after cleaning, why would a few days make a difference?
Is it some temporary oxidation in the track?
I think oxidation is as big a problem as dust.
You should also clean the wheels of all your engines and rolling stock using the same method.
I use a fine wire brush originally purchased for cleaning suede leather shoes.
So the problem with petrol is that while being a solvent, it is volatile and evaporates very quickly.
Which means that it leaves no residue and maybe you get new oxidation.
I would use an oil-based cleaner such as "3-in-one" if available near you.
Or something like sewing machine oil.
On my old tin-plate track (English similar to Märklin) I use a track rubbber which is abrasive but cleans enough to keep trains running.
I don't need to do that very often.
Both Märklin and Fleischmann sell track rubbers.
Offline Rocca
#3 Posted : 25 August 2021 10:01:10(UTC)
Rocca
Hi Kimball, your suggestion of the oil based cleaner is very appreciated and I'll try with the rubber too. I've one Roco's. I've read in an old Märklin booklet they suggest parrafin, which is what Germans call Petroleum. So something different from English petrol.
Thank you so much for your help!
Stefano
Hi Stefano,
thanks 1 user liked this useful post by Rocca
This page was generated in 0.237 seconds.
