Offline Puttputtmaru
#1 Posted : 27 June 2021 03:33:54(UTC)
Puttputtmaru
Has anybody use NooX Id as mentioned in this video with Marklin tracks. It looks like a great product, may be too good to be true. I am a little worry about it action on the rubber of traction wheels on locomotive.
thanks 3 users liked this useful post by Puttputtmaru
Offline rbw993
#2 Posted : 30 June 2021 17:52:53(UTC)
rbw993
At the end he cautions about using it with traction tires.
Roger
#3 Posted : 30 June 2021 19:27:14(UTC)
The funny guy on youtube about track cleaning is an Aussie. "Don't do it!" is his slogan.
I've used the eraser thing, but no more. Alcohol has some water, so a no-no too. The Marklin dudes reccomend karosene. I use it, and it works great! Just wipe away the residue after applying it with a cotton swab.
Offline Copenhagen
#4 Posted : 30 June 2021 22:04:21(UTC)
Copenhagen
Some people have been using track rubber for years and years without wearing their tracks down. Even Märklin Wunderland used it extensively (not anymore because it's too labor intensive). Even if there is water in the alcohol, and even if you use a mixture of soapy water on a piece of cloth, it'll evaporate quickly (Märklin Wunderland also used soapy water until not too long ago... seen in a video on their track cleaning routine). Some of the old types of track may not react well to moisture of course.
thanks 2 users liked this useful post by Copenhagen
#5 Posted : 01 July 2021 00:13:07(UTC)
The track rubbers don't so much wear down the rails. They do leave residue behind you have to brush away. It's liike a dust and can get into gears. The oil woill hold it in.
Offline Copenhagen
#6 Posted : 02 July 2021 11:05:39(UTC)
Copenhagen
I'm not advocating the use of track rubber, especially on Maerklin tracks where the pukos are higher than the tracks in turnouts and crossings. I just think the criticism against track rubber is exaggerated.
Offline ocram63_uk
#7 Posted : 02 July 2021 11:10:36(UTC)
ocram63_uk
Where would you buy Kerosene from ? In England you can't even buy a syringe without having to speak with a doctor and explain what you need it for 😱😱
Offline Copenhagen
#8 Posted : 02 July 2021 14:13:41(UTC)
Copenhagen
Kerosene can be bought in DIY markets (hardware stores etc) in plastic bottles. Kerosine is called "petroleum" in my country. I can buy syringes and needles in pharmacies without problems.
Offline phils2um
#9 Posted : 03 July 2021 05:11:17(UTC)
phils2um
Kerosene is also used as a camping stove fuel. Check the label.
Phil S.
thanks 1 user liked this useful post by phils2um
Offline Legless
#10 Posted : 03 July 2021 08:17:05(UTC)
Legless
We used kerosene for lamps in the old days back when we walked with the dinosaurs.
Legless
thanks 1 user liked this useful post by Legless
#11 Posted : 03 July 2021 09:14:06(UTC)
Yes indeed we did,
and moving forward into the 21st century, it is also the fuel-type used by jet aircraft ("kerosene canaries") !
#12 Posted : 03 July 2021 16:27:50(UTC)
Alcohol can actually get the rails too clean. You want some sort of conductive residue left. As soon as some new dirt begins to build up, that will help current get to the wheels.
While karreosene isn't a great conductor, it is enough to help, as it is slightly oily.
Offline Rwill
#13 Posted : 03 July 2021 18:05:14(UTC)
Rwill
I find the best way to clean the tracks is to run trains on them and definitely not to use much oil on the loks.
thanks 3 users liked this useful post by Rwill
Offline twmarklinfan
#14 Posted : 04 July 2021 08:09:03(UTC)
twmarklinfan
I use isopropyl alcohol BUT it has to be the 99% pure. The 70% version is to be avoided as the 30% is water. The 99% has great cleaning properties especially useful for cleaning out all that old oil and dirt when servicing locos.
Quite an interesting video on track cleaning
thanks 1 user liked this useful post by twmarklinfan
#15 Posted : 04 July 2021 14:46:12(UTC)
So, hand sanitiser it is then ?
Offline grnwtrs
#16 Posted : 04 July 2021 22:31:32(UTC)
grnwtrs
I read about having that in 99*% bottle, in the MML of days past. I had a very hard time finding it in the what we call
drug stores, but finally found a couple of bottles.
I only use it sparingly. Seems to work for what little track I have. And what little run time it receives now.
Regards, gene
This page was generated in 0.643 seconds.
