Offline H5463
#1 Posted : 23 June 2021 15:41:41(UTC)
H5463
I need to make them stand, which is an extra work. I put a plastic sheet attached on the bottom of the legs, trying to hold them up. Is it only me or someone else having the same problem?
Offline Copenhagen
#2 Posted : 23 June 2021 16:34:11(UTC)
Copenhagen
I use the same method. The plastic sheets for windows in most model kits are well suited. I have used super glue but it is often tricky to work with (possible discoloration) so lately I've used Noch's Hin- & Weg-Kleber. You can also use white glue. The figures need to be supported while the glue is drying of course. There will be places like in tall grass and rough areas where this method doesn't work.
#3 Posted : 23 June 2021 17:13:21(UTC)
wood glue.
#4 Posted : 23 June 2021 17:30:25(UTC)
Yes, all of the above, or tacky sppots. The Woodland Scenics 100 count is $6 US. A half of one is plenty. Then they stay in place and can be moved anytime.
Offline Copenhagen
#5 Posted : 23 June 2021 21:22:26(UTC)
Copenhagen
Interesting. Never heard of that product before. (They're actually called sticky spots).
https://woodlandscenics....nics.com/show/item/C1167
#6 Posted : 24 June 2021 05:10:06(UTC)
If the figures are to stand on a plastic surface (typically a station or building) then I use Faller super-expert glue as here :
If the figures are not on plastic but standing on ballast or other scenery granules such as here:
or on a soft paving surface such as here :
or soft scenery surface such as here :
then in those situations I use superglue. I find this gives a firm fixture as opposed to the contact adhesive glues such as "Hob-e-tac"
#7 Posted : 24 June 2021 10:52:57(UTC)
I use Blu-tack.. Sometimes I use too much and Webmaster calls it Chernobyl Cow Pat..
I don't know if it is available internationally, but here is a wikipedia blurb about the stuff -> https://en.wikipedia.org/wiki/Blu_Tack
#8 Posted : 24 June 2021 11:48:11(UTC)
... Chernobyl Cow Pat..
Laugh LOL
#9 Posted : 24 June 2021 13:30:41(UTC)
Any type of glue. If on plastic as said Faller glue and in other areas PVA glue.
I find if they have a good diet and plenty of of walking or running in the fresh air will keep them fully fit and able to stand tall. Regular medical check ups ensure my people have good health and an enjoyable life on the layout.
This page was generated in 0.343 seconds.
