Offline jonas_sthlm
#1 Posted : 22 June 2021 12:53:40(UTC)
jonas_sthlm
Have you also be needed to glue when the construction doesn’t stick together Confused
http://www.modelltag.se/images/private/MOV_0164.mp4
#2 Posted : 22 June 2021 13:11:49(UTC)
Jonas, you shouldn't need to. If the coupler guide plate doesn't seat tightly with the body on, I would first try a thin shim over it. Even cardboard if you don't have a thin sheet of plastic. You shouldn't even need to do that. What gives with Marklin at times?
My #36182 Vectron out of the box first run, a cardan shaft dislodged under a train load. The bogie with the traction tire, as the other's wheels spun.
This page was generated in 0.213 seconds.
