#1 Posted : 04 June 2021 14:56:41(UTC)
looks attractive, has 2 rubber tyres, will increase it to 4, headlights, markerlight front & rear, interior lights front & REAR, lit destination sign front & rear., added sound decoder (V 5.0 = PLUX22) and a round speaker fits nicely into the provided space., soldered a wire to the pantograph supporting arm, drilled a small hole into the housing and conneted the wire, now its ready for catenary operation.
the model overall looks good, the details are superb
Online marklinist5999
#2 Posted : 04 June 2021 15:54:37(UTC)
John, long distance headlights?
#3 Posted : 05 June 2021 04:56:59(UTC)
No, not that I've noticed them, I'll have another look
the loco cost me incl. sound (own sound decoder) Euro 225.00 (not incl. freight & import charges)
#4 Posted : 05 June 2021 08:46:35(UTC)
I've added the highbeam to the fron light circuit board, a bit fiddly, had to file out the window to be able to fit the led into it and the second task was to alight them to the window, I was able to scrape off the protective film of the copper wire (+) and the (-) I've added a copper wire and connected it with 2 resistors to Aux 7, first the lights were much to bright so I've reduced it to 1`.
I've only attached the high beam to the front of the loco
#5 Posted : 06 June 2021 20:07:02(UTC)
If the one with sound insrtalled is nearly the same price as a Marklin, if the Marklin has long distance headlights, thats a plus.
#6 Posted : 07 June 2021 04:34:54(UTC)
At this point, with Maerklin conceding on the Vectron, we should put pressure on them to put out more non-Hobby models of the Traxx locomotives too.
My two cents worth.
This page was generated in 0.404 seconds.
