Offline husafreak
#1 Posted : 03 June 2021 05:10:16(UTC)
husafreak
Another item from the land of "not quite right", same seller actually. Does anyone have one of these and can comment on the lighting? The Marklin description says the control car has 3 white lights changing over to two red marker lights, LED lighting. This "excellent condition" set came with the lights not working at all. After cleaning the contacts and making the bend correct I have the white lights going forward but they do not change to red markers when reversed. I removed the light fixture to check it out with a direct low voltage source but it is the same out of the car. No red lights just white. I have asked the seller to replace or refund this one but I thought it quite odd that it only works partially so I ask?
This page was generated in 0.190 seconds.
